Question about MSI KT4V (MS-6712) Motherboard
Drivers Radeon 9800 driver issue after adding extra RAM
Videocard Radeon 9800 cant be seen in device manager , it cant be installed either with the original drivers from the CD. Can the recently added RAM be the reason?
If drivers ARE being installed it shows no picture, just some coloured lines and eventually several error messages, including "insert new boot device{...} after reboot.
rgds,
  • 979 Answers
Hello sir, reinstalling the OS with the radeon 9800 will do the job.
Posted on Sep 14, 2009
  • Jerry Umali Sep 18, 2009
    Hello sir, the reason why your driver isn't working has several reasons:
    1. you are installing a wrong driver. make sure you have the right one.
    2. your OS does not support your driver. get the driver for the right OS, you can go to www.driverguide.com for your driver needs.
    3. your OS is a mess, try reinstalling the OS with your card installed. Then load the device driver for your radeon.
    post me up on your progress.
6ya staff
SOURCE:
Geforce n520 code 43
The card or the driver has failed. It's likely a driver issue. Try powering off the computer and restarting, if it doesn't happen again it could have been a temporary issue. If you haven't installed the latest drivers I would suggest going to nVidia's site (http://www.nvidia.com/download/driverResults.aspx/77224/en-us) and install the latest drivers for your card. If you've already installed them, or if this occurred after updating the driver, I would suggest trying to rollback the driver to a previous version. This can be done in the Device Manager. From the Start Menu select Control Panel > Hardware and Sound>Device Manager. You will see a drop down list in the Device Manager, and you'll want to select Display Adapters and you should see your videocard. Right click the card and select Properties. Select the Driver tab and then select the button entitled Roll Back Driver and follow the prompts.
If updating or rolling back the driver doesn't help, it's possible that the videocard is failing and may need to be replaced.
Aug 11, 2014 | Computers & Internet
I have an ati radeon ed6600 and i cant find any drivers for it can u help me plzzz..... :)
I've never seen a Radeon "ed6600" videochip, and can't find one listed ANYWHERE, so I suspect you've misidentified your GPU. You MIGHT have a Radeon HD6600M GPU; you can download the drivers for it here:
http://www.amd.com/us/products/notebook/graphics/amd-radeon-6000m/Pages/amd-radeon-6000m-series.aspx
Open that page, and click on "Find a Driver" in the upper-right corner of the webpage.
The "Component Category" for your video card is "Notebook Graphics"
The "Product Line" is "Radeon HD Series"
The "Product Model" is "Radeon HD 6xxxM Series"
Lastly, choose the operating system you're using; Win7 32-bit, Win7 64-bit, Vista 32-bit, Vista 64-bit, or Win XP 32-bit. Select your operating system, then click the green "View Results" button.
The next page that opens will provide a direct link where you can download the drivers for your Radeon videocard. BE SURE to read the Release Notes and the Installation Instructions BEFORE you begin the driver installation.
Keep in mind that Windows must reboot when changing drivers, so DO NOT try to delay the process. Windows deletes a LOT of old files during the reboot so that they won't conflict with the new driver files being installed. If you delay or interrupt the process, you could have an unbootable mess on your hands.
Best of luck with this; let us know how it turns out.
Apr 25, 2011 | ATI Mobility RADEON Graphic Card
Hello, my monitor has streaks running through top to bottom. I can still read the font but just barely. What might be causing the streaks? The machine is factory Sony P4 3.2 tower, the video card is the...
Possibly conflicting with something or the card has failed or it could be a driver issue try & update the drivers if this doesn't work check in device manager if there is a yellow exclamation mark then there is a conflict somewhere, if driver update doesn't work & no conflicts are found your card has failed & will need to be replaced.
Oct 26, 2017 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Gigabyte Radeon HD 4650 1GB (AGP) - unknown PCI device
Hello.
ATI (AMD) does not "technically" support AGP products, but go to this link.
http://support.amd.com/us/kbarticles/Pages/CatalystAGPHotfix.aspx
To download the driver. Versions 9.6 and 9.7 will work, depending on your OS. Just download and install the drivers and the yellow exclamation mark will go away.
For more information please visit: http://forums.amd.com/game/messageview.cfm?catid=260&threadid=117644
Hope that Helps.
Jan 29, 2010 | Gigabyte RADEON HD 4650, Video Card
Please,update my videocard drivers
First of all you need to know what video card you have. If you have Windows and I assume you do go to Start > Control Panel (switch to classic view) > System click on Device Manager and in the list find 'Display Adapter'. The name of the driver appears. Make a note of it. Go directly to the website of your driver's manufacturer. Follow the instructions to download and install the right driver. Restart your computer to let it take effect.
Warning: this is the manual way to update. If you are not a tech guy, attempting to change video drivers could make your computer inoperable or cause severe problems. As a result, you can rely on a driver detective program to help fix the driver issue automatically & accurately. This way also saves you time & energy.
Jan 09, 2010 | HP NC6230: Intel Pentium Mobile 760 2.0GHz...
VIA CPU to AGP Problem with 3Gb and Vista
Chances are good that your third 1gig memory module is faulty. Windows blue screen of death at startup is a typical symptom of faulty RAM memory.
Try replacing the third 1gig DIMM with another of the same type.
Let me know if this works or not.
Regards,
Graemevm
Apr 22, 2009 | Abit IP35P Motherboard
EA Game ''Spore'' - Videocard & Driver Issue
The card does not have the requirements to play the game. You would need to upgrade to a better video card if you want to play this game on your system. Sorry.
Jan 10, 2009 | Acer Aspire 5315 Notebook
Well, I can solve it but it is somewhat bad news. Basically your video card is not powerful enough. Here are the ATI specs from the EA website;
  • ATI Radeon™ series
  • 9500, 9600, 9800
  • X300, X600, X700, X800, X850
  • X1300, X1600, X1800, X1900, X1950
  • 2400, 2600, 2900
  • 3450, 3650, 3850, 3870,
  • 4850
    and here are NVIDIA
  • NVIDIA GeForce series
  • FX 5900, FX 5950
  • 6200, 6500, 6600, 6800,
  • 7200, 7300, 7600, 7800, 7900, 7950
  • 8400, 8500, 8600, 8800
  • 9600, 9800, GTX 260, GTX 280
    I would recommend buying a new video card. You can pick up a NVIDIA 8400 thru 8600 for about $30 or $40 from Frys.com or newegg.com sometimes cheaper with rebate.
    They are fairly easy to install.
    Good Luck.
    Dec 14, 2008 | ATI RADEON 9250 256MB PCI (Retail) Graphic...
    Radeon 9800xt update drivers
    this site containes the driver you need, download "catalyst software suite" the driver for radeon 900series is in there. ....please vote for my help thanks
    Oct 27, 2008 | ATI RADEON 9800 PRO (256 MB) Graphic Card
    Problem is you need to install Vista which support 4Gb! Look for specification on Vista you have!! Mostly XP and Vista support 2Gb!
    The problem is in your OS. 32 OS support max 2Gb of ram they detect you 3gb but they couldn't operate with all!!
    Jan 25, 2008 | MSI KT4V (MS-6712) Motherboard
    MSI KT4V (MS-6712) Motherboard Logo
    201 people viewed this question
    Top MSI Computers & Internet Experts
    Alun Cox
    Ekse
    Thomas F. Schneider
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
