Question about Kenwood KVT-715DVD Car DVD Player
CD into the NAVI MAP slot - cannot eject it !
I have wrongfully inserted an audio CD into the NAVI MAP slot (Kenwood touch screen, flip down ??? model) on my 2009 Subaru Impreza STI. It's a system with two slots (the above one is for audio-DVD, and the below slot is only for navi DVD MAPS).
As the navi / audio system was never set up by the dealer, there's no menu on the touch screen to press the EJECT button, and it seems that the side buttons are not activated.
Dealer told me on the phone that, since the sistem never had never been set up, and neved got inserted the correct DVD with map with some special setup software, it did not installed the software, and there's no way to eject now the wrong CD. How stupid is that?!
Do you have any suggestions of how to eject the CD from the NAVI slot?
Thank you.
Posted by iulian_dorde on
How do I have to restart my eclipse avn52d car audio cd drive after I changed my car battery ?
You must be inside the Eclipse in order to unlock the radio's security system.
Insert the key in the ignition. Turn it clockwise one notch so some of the car's controls turn on, but not the ignition.
Press the radio's "On" and "Screen/Text" buttons at the same time and hold both down until "SEC" appears on the radio's screen. After two seconds, the screen will change to read "DISC."
Press the "Open" button on the front of the radio. The front panel should open it.
Insert the Key CD into the CD slot. The message "SEC" appears. You should have received this CD when purchasing the car. If you don't have this CD, contact your Eclipse retailer for an extra one.
Eject the Key CD by pressing the "Eject" button and close the front panel of the CD player.
Jan 27, 2018 | Eclipse Car Audio & Video
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
GPS says no application
Go into settings then guide settings. Tap the sd slot card so the radio can read it should work now
Jul 04, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
How do I get cd in cd player on KDC-X879?
Press Eject button top right to drop the front panel down, insert CD in to slot.
You can download the manual here:Manual
Jan 25, 2012 | Kenwood eXcelon KDC-X879 CD Player
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Nov 18, 2009 | Kenwood KDC-516S CD Player
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
Disc stuck in deh-p7000r plays but wont eject
should be a small pin hole next to the disk tray, 2 or 3mm wide. Insert a pin and that should then cause the disk to be ejected.
Aug 25, 2017 | Pioneer DEH-P7000r
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Kenwood DNX 7100
In order to access the DNX7100's bulit in SD card slot, you have to press the CD/DVD eject button for about 5 secs. It will fold down to reveal the SD slot. This slot is only used for Software and Map updates via a SD Card.
Jan 08, 2008 | Kenwood DNX7100 Car Video Player
Kenwood KVT-715DVD Car DVD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
