Fax Pick up
Hi Greg- double check to make sure the machine is set for auto pick up.To do this:
1)On the control panel press MENU
2)Use the < or the > button to select Fax setup, then press ENTER.
3)Use the < or the > button to select Fax Recv. Setup and then press ENTER.
4)Press ENTER to select answer mode.
5)Use the < or the > button to select Automatic, then press ENTER.
The control panel display shows the answer mode you specified.
If this fixes your problem PLEASE rate this as fixed. If not, don't rate yet.Just add a comment and I'll be glad to assist you further.
Jeff
