Question about Emerson Black Microwave Oven
Emerson microwave, #MW8119SB, push start button to start cooking
When I push the start button to start cooking, it beeps like 3 times and resets the clock and it won't cook anything! I reset the clock and enter the time again to cook and press start and it beeps 3 times again and resets everything! I've only have this microwave for a year and a half! Please HELP!!! I
Posted by Kelly on
Anonymous
  • 3 Answers
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
I just moved in here 2.5 weeks ago. At first the none of the numeric buttons on the Emerson mw8119sb worked. Then, after punching them for a while, the 6 worked.
First of try to disconnect it, wait for a minute, then re-power it. After internal tests it's supposed to come up with initial settings (like time/date etc.)
May 13, 2015 | Emerson Mw8119sb Microwave Ovens
Reset emerson microwave
There is no reset button. You will need a control board.
Dec 13, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
Nov 25, 2014 | Emerson MW8119SB Microwave Oven
Emerson microwave mw8119sb
Sounds like you had a component failure during a cook cycle. You need an ohm meter and experience to troubleshoot this problem.
Oct 07, 2013 | Microwave Ovens
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Emerson MW8997B desktop microwave beeping
Hi, probably something happened with the PCB due to an abnormal current fluctuation.
You should go to a service center.
Nov 13, 2017 | Emerson Microwave Ovens
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Emerson Black Microwave Oven Logo
815 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
