The pop itself isn't necessarily a bad thing, but a burn smell and the fact that it's only outputting a crackle likely means that the built-in amplifier circuitry has been overloaded. This can happen a few ways:
1) Faulty power, either a bad cord or a bad outlet
2) Plugging the output of a power amplifier into this speaker - because it has a built in amplifier, this speaker only wants a non-powered line input
3) If the Thru output is (accidentally) plugged into anything that provides phantom power, that could overload the circuitry.
4) A short due to liquid or moisture contact - these cabinets are most certainly not waterproof
In any case, the amplifier part of the circuitry IS replaceable. If you're not comfortable buying one and replacing it yourself (I'd recommend eBay), take it to any shop that sells similar items. If you're extremely lucky, it was just a fuse that needs to be replaced, but chances are you'll need to replace the whole amp.
SOURCE: Repair a Mackie SRM 450 Speaker
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
