Question about Cameras
Olympus mju 700 - error D: 5e02
Hello, I have a problem with Digital Camera Olympus mju 700 (very frequent problem with Olympus cameras). It has 2,5 years (so no longer warranty). After turning on my camera, noisy sound starts, lens go in and out and then LCD goes to whole blue screen with an error message ''D: 5e02''. I can not take any pics. I have read all the discussions on this forum (with many strange solution suggestions), but I am still not sure if I can fix it by myself. Or should I contact service-center? Please send me an answer. Thank you. Jakub from Europe
Posted by jakub_ba on
Anonymous
    Novelist:
  • 133 Answers
Hello Jakub,
As you might already know that you are not the only one who is getting this error.. there are thousands of others with you .. If that makes you happy :D
This code is a troubleshooting service code for "malfunction of focus motor/sensor". It is a motor/sensor issue and is normally caused by sand or dirt in the lens cover mechanism. Try to turn on camera while holding it with the lens pointing up.
You might even try hitting the camera on your palm in that position (by hitting, i don't mean a real HIT .. be sure that you are gentle not to break the camera).
If that doesn't work then try this... when the lens is trying to come out and cannot come out completely then you can assist the lens by pulling it out manually (once again, understand that its a delicate camera and I don't want you to show how powerful you are by pulling it with all your mighty vigor.. be hard and gentle at the same time .. I hope you understand what i mean)
Please let me know if any of the above steps work for you and do rate the solution :)
All the best.
Regards,
Srinivas
Posted on Apr 08, 2009
Toestel werkt niet blauw scherm geef error code 5f08 en 5e02
1 van de mogelijke oplossingen is dat er vuil in de binnenkant van de lens zit. Als dat het probleem is, is de oplossing de camera op te starten met de lens naar boven.
Andere oplossingen kan bv update van de software via de olympus software
Aug 21, 2009 | Olympus Stylus 700 / 700 Digital Camera
Getting error 5f08 5e02 in my olympus camera..
Getting error 5f0a 5f08 5e02 in my olympus camera..
Jan 26, 2009 | Olympus Stylus 700 / 700 Digital Camera
Stylus 700 error D:5f08 5e02
The error message (D: 5f08 5e02) means that your lens is dying / dead. It just happened to mine (on the Mju 700, but it's the same thing) and I was told that it could be repaired, but it would cost as much as a new camera. I've only had mine 2 years and I've been really careful with it, so I'm a bit annoyed, but I have used it a lot!
Dec 22, 2008 | Olympus Stylus 700 / 700 Digital Camera
Camera olympus error D: 5f08 5e02
The error message (D: 5e02) means that your lens is dying / dead. It just happened to mine and I was told that it could be repaired, but it would cost as much as a new camera. I've only had mine 2 years and I've been really careful with it, so I'm a bit annoyed, but I have used it a lot!
Dec 06, 2008 | Olympus Stylus 700 / 700 Digital Camera
Camera lens jamming up
there isnt a quick fix on this tiny motors and switches im afraid you need to send thia to a shop, the home postition sensor is failing nor the motor itself is defective
Sep 29, 2008 | Olympus MJU 400 Digital Camera
Olympus camera error
something is causing the camera to not boot up properly whether it is the lens or something else.. you may try to power reset... hold down the power button for 10 seconds while the battery is out of the camera
Sep 04, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus digital code D : 5f08 5e02 Camera not functioning
Camera will not turn on and displays D :
5E02
shutter will not remain open then the above is displayed
Jun 28, 2008 | Olympus Stylus 700 / 700 Digital Camera
5e02
hi the following answer was given by another user . Just make a try. Good luck!
"BY TRIAL AND ERROR I FIXED MY mju 700 SHOWING THE ABOVE ERROR
IF YOU PRESS AND HOLD THE ok/function BUTTON, AND TURN THE CAMERA ON AND OFF A FEW TIMES WHILST KEEPING THIS BUTTON DEPRESSED, IT SHOULD HOPEFULLY SORT ITSELF OUT?!
(NOT SURE IF IT MAKES A DIFFERENCE BUT MY DIAL WAS SET TO scn FOUND INBETWEEN guide & the wobbly hand.
I ONLY TURNED on/off/on AND IT FIXED THE ERROR, IT MAY TAKE MORE FOR YOU.....I'M NOT SURE AS MINE IS NOW FIXED!
IT WORKED FOR ME, HOPE THIS HELPS, GOOD LUCK!"
May 23, 2008 | Olympus Stylus 710 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
I can't turn my Olympus camera MJU-700 on,it gives me an error message D: 5f08 5e02,but I can still view my pictures.
I Have the same same problem , it happens to be the sliding door playing up ....need to take it to a repairer(Olympus) to fix ...hope this helps
May 08, 2007 | Olympus MJU 400 Digital Camera
Cameras Logo
2,021 people viewed this question
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
