Sharp EL-531VB Calculator Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is shift log feature in sharp EL-531 W calculator
Shift log feature
k24674
Level 3:
  • Sharp Master 8,093 Answers
  • Posted on Sep 18, 2009
k24674
Sharp Master
Level 3:
Answers
8093
Questions
0
Helped
4675587
Points
21596
The [2ndF] key allows access to other functions. I do not have the calculator under my nose, but I suspect under the [2ndF][LOG] you access the 10 to the power x function [10^x] or [10 to the x].
Hope it helps.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1282
Points
How do I find the antilog of a number using my EL-531WH Sharp calculator?
Linear equations sharp el-531
You cannot solve linear equations on a SHARP EL531. If you would like a calculator that solves equations, you need to get a SHARP EL W506
2answers
Log2(0.25)
Press
ln . 2 5 / ln 2 = or
log . 2 5 / log 2 =
1helpful
2answers
Log2(0.25)=-2
You can compute the logarithm of x to any base by computing log(x)/log(b) or ln(x)/ln(b). So, press
log . 2 5 / log 2 =
I cant figure out what is the shift key on my calculator. I have a Sharp EL-531W. I tried the 2NDF key and its not coming out right.
Regardless, that is the markings on the SHIFT key on Sharp Calculators. The 2ndF key accesses the functions that are marked on the face of the calculator, not on the top of the keys.
How do i perform log and log inverse or antilog calculations on my sharp EL W-535 calculator
Press the log key, enter a poistive number and press the = key.
To calculate the inverse of the decimal log use SHIFT LOG to access the function 10^x (the inverse of the log function.)
3helpful
DB to Power ratio using antilog
The conversion formula is
# dB =10*log(Pout/Pin) for say an amplifier.
For your case
Pout/Pin= 10^4 then #dB =10*log(10^4)=10*4=40 dB
Let us take a less obscure exemple
# dB= 57.39, what is the power ratio?
10*log(Pout/Pin)= 57.39
log(Pout/Pin)=57.39/10=5.739
Pout/Pin=Ratio =10^(5.739)= 548276.9649, not a number you would hear or see quoted, but a correct value.
To calculate the power ratio
  1. Convert the decibels in Bels (divide by 10)
  2. While the number just calculated is still in Answer memory (ANS), press [SHIFT] [LOG] to access the the 10^x function
  3. Press [SHIFT][(-)] to enter (ANS)
  4. Close the parenthesis [)]
  5. Press [ENTER]
Here is the screen capture for the calculation one way and back.
10helpful
2answers
How do I get factorial function on a Sharp EL 531 WH
The factorial function is shown on you calculator as n! To calculate factorial 4 you proceed as follows 4[2ndF][n!][=] this gives 24
Hope it helps.
15helpful
Can you find shift button on sharp calculator (EL-531WH) D.A.L
On Sharp calculators, the shift key is the [2ndF] key.
Hope it helps.
Exponential form
Hi - You can download the manual from the link underlined in blue below:
EL-531 W
You need to set it to "SCI" i.e. scientific mode to show the exponents:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
30helpful
6answers
User's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
