Hi
You don't say if the car is running or not. Are you able to start it? If not check your battery, a low battery will give this problem along with the inability to move it into gear(automatic)
If it is running the engine management light should also be illuminated, you need to get the code read to go any further with this. Bit of a problem if you don't have a code reader (you can pick them up cheep on EBay) You may also be able to get the code display using the cars 'hidden diagnostics' see
http://www.bluejag.co.uk there is a readout of the current fault code that can be found as you step though the diagnostics.
Hope this helps some.
