My mac screen is on x ray mode how do I change it back
Posted by Paul Jobling on
Jessica D
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
Press the Control-Option-Command-8 key combination.
Posted on Aug 30, 2013
How to access my laptop without a password
Mac OS X: How to start up in single-user or verbose mode You can use key combinations to start up the computer in either single-user mode or verbose mode. These may be used for troubleshooting or software development.Starting up in single-user or verbose mode
    1. Shut down your Mac if it is on.
    2. Press the power button to start the computer.
    3. Immediately press and hold the Command key and one of the following:
    • the "s" key for single-user mode. (Command-S)
    • the "v" key for verbose mode. (Command-V)
You have successfully entered single-user or verbose mode when you see white text appear on the screen.To exit single-user mode type reboot then press Return. Verbose mode exits automatically when the computer's startup process progresses sufficiently and the blue screen appears. Use the s option
Type sudo passwd (username)
Type exit
reboot
password is changed
Mar 18, 2014 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
For some reason mt blue ray player was saying 1080i and not p so i went into menu and changed to 1080p but tv is now saying mode not supported and i cant get back into the menu on the blue ray player to...
Try to make use of the yellow video cable, the cable that is part of the RCA cable and try to set the TV to AV1 as soon as the video cable is connected from your BD player to your TV. Turn on your Bd player and you can now set the TV to its correct resolution. Best thing also to reset oyur bd player back to its factory settings.
Oct 22, 2010 | Samsung BD-P1400 Blu-Ray Player
Damaged 24 iMac screen - want to use ext monitor via "mirroring" in screen preferences, but cannot access system preferernce due to damaged screen...any suggestions
There is an elegant way to solve this, but it requires another compatible model Mac.
Boot the damaged Mac into FireWire Transfer mode by holding down the "T" key immediately after hearing the startup chime. Attach a FireWire cable between the two Macs. Start up the other Mac by holding down the "option" key after hearing the startup chime. Choose the startup drive from the broken Mac. Now your good Mac is booted off the drive of the broken Mac, and any configuration changes you make will be made on the hard drive of the broken Mac.
Attach the external monitor temporarily to the good Mac. Open System Preferences and set the monitors up in mirrored mode. Shut down the good Mac. Then hold the power button in on the broken Mac until the power turns off, and remove the FireWire cable.
Now move the external monitor to the broken Mac and boot it. It should come up in mirrored mode.
Jan 20, 2010 | Apple Computers & Internet
The circular timer startup screen NEVER STOPS! Powerbook G4
Hi
Safe Boot is a special way to start up in Mac OS X 10.2 or later when troubleshooting. Safe Mode is the state Mac OS X is in after a Safe Boot. To perform a Safe Boot, hold the SHIFT key as your Mac starts up.
Some features don't work in Safe Mode Safe Mode can be useful for troubleshooting. However, certain Mac OS X features do not work in Safe Mode. For example, you can't use DVD Player, capture video in iMovie, use audio input or output devices, or use an internal or external USB modem. The behavior of some devices such as an AirPort card may vary depending on computer and Mac OS X version.
Safe Mode in Mac OS X 10.5 or later also disables Quartz Extreme (hardware accelerated graphics). Applications that depend on Quartz Extreme will not open, and the Mac OS X menu bar will appear solid even if "Translucent Menu Bar" is enabled in Desktop & Screen Saver preferences.
Aug 03, 2009 | Apple PowerBook G4 Mac Notebook
Sigmatel s4
U can find a house symbol on the bottom of your touch screen. Jus click tat and u find menu options.In tat select settings and select dual sim settings. There select Dual Sim
Aug 14, 2008 | Handmark Software MobileLists (950142) for...
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Computers & Internet Logo
75 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
