Question about New Bright Remote Control 1:12 Scale Pro Wolf Flat Track Racer 14"R/C Pro Wolf, Flat Track Racer
So. I took the Body cover off My New Bright Wolf Pro R/C Truck And The Red and Yello Wires came out the back, I thought they went to the motor, but they dont.. They go to a sencer of some kind for the "Motor Protection Indicator". Now that there Out, The R/C car wont go noware And when i Cross the wires together to complete the circute The light on top the body flashes saying the motor is over heating.....uggg and it ges noware, there has to be something i can connect to the yello and red wire to trick the system saying( Alls O.K) and what ever was there was as small as agrain or rice, probly something just dumb
Posted by Jorell Huguley on
MeAndMyBrain
    New Friend:
  • 52 Answers
The sensor is a resistive load sensor. The resistance changes as the motor gets hot. Solder the wires back onto the board and whilst keeping the model off of the ground, put it into drive mode. If it doesn't go, then wet your finger and bridge the two solder points on the sensor. Don't worry, you will not get any electric shock as the voltage and current are too low.
If it still doesn't drive, then wiggle the motor wiring at the motor. If still nothing, then press lightly on that sensor pcb. There may be a broken track on it. If it is broken, then you cannot solder it. You then need to go to Maplins (if in the UK) and buy a small bottle of pure silver paint. Where the solder points meet the circuit resistive track (it'll be black carbon looking), paint one blob of silver conductive paint onto each of the track beginnings. Let those dry (five minutes) and then try it. It should work. The silver paint will only work if the wet finger trick on the black carbon track works. If no carbon track, then it may be a thermal resistor (thermistor). Replace it. Maplin sells them too, so just buy a few different types (very cheap) and temporarily solder one in place until it works.
Posted on Nov 13, 2013
I have a 2005 ford f450 with 6.8 v10. Couple problems, very slow repsponce from pedal, only revs to 3200rms,and tops out at 40mph ,very loud whine/ squeel from what sounds like driver side valve cover, had...
The butter fly inside the throttle body is not opening or shutting with the gas pedal. Replaced the whole throttle body assembly and GPS and the floor pedal assempby and still no luck!
Jan 14, 2013 | Cars & Trucks
1990 gmc truck 5.7 liter. won't start after throttle body spacer
PVC simply recycles the blow by gases. You have either blown a fuse, or your fuel pump is not delivering gas to the motor.
Jun 29, 2009 | 2003 Chevrolet Malibu
Just relpace a seized up inducer motor/flu vent. 3 red blinks
the diagnostic codes should be listed next to the wiring schematic on the inside of the blower compartment door. if the inducer motor was bad I bet you have a tripped flame rollout switch around the burners. look for a very small red button between two wires on a disk around the burners. push on the red button to reset the switck. this should turn your furnace back on.
Mar 28, 2009 | Goodman GMS90703BXA Heater
No headlights not even manually
switch not grounding properly
Mar 01, 2009 | 2002 Chevrolet Silverado
Dv 10 Lamp trouble
examine the lamp
any fault should be visible on the tube.
i assume you mean the pj lamp glowing bright red
Feb 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Wall oven again
Singed wires suggest electrical fault or excessive heat, i personally suggest you have the unit checked out by a professional to ensure your own safety.
Jan 22, 2008 | Ovens
New Bright Remote Control 1:12 Scale Pro Wolf Flat Track Racer 14"R/C Pro Wolf, Flat Track Racer Logo
1,104 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
gerry bissi
Marvin
Marvin
Are you a New Bright Toy Expert? Answer questions, earn points and help others
