Question about SanDisk Sansa e270 MP3 Player
Can I charge sansa clip in 220v socket - SanDisk Sansa e270 MP3 Player
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: sansa clip 2gb
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 28, 2008
Anonymous
  • 36 Answers
SOURCE: sansa clip mp3 player wont charge
Try to charge it on another computer to determine if it's your computer. If the other computer works, then the problem is with your computer. (If your computer has multiple USB ports, you could also try another one.)
If the other computer does not work, then the problem is likey your cable. If you have another friend with the same device, borrow their cable and try it. If it works, then you need a new cable. If it doesn't work, then your Clip has issues. You could try doing a complete reset on it by sliding the power button up and holding it for 15 seconds (as described in the manual at http://www.sansa.com/sites/default/files/downloads/CLIP_UM_0608_ENG.pdf).
Posted on Jan 05, 2009
Anonymous
SOURCE: SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Posted on Jan 29, 2009
Anonymous
  • 63 Answers
SOURCE: sansa clip
battery maybe?
Posted on Jun 23, 2009
Anonymous
  • 803 Answers
SOURCE: sansa 4gb clip purchased will not hold charge
You should and just tell them that the battery is deffected
Posted on Oct 01, 2009
This isn't a problem (I hope) but my Sansa clip didn't hold a charge for very long. Can I use my cell phone charger to charge it? It fits the connection fine.
Yes, assuming you're referring to the connection at the end of the Sansa cord and not on the Sansa itself. The Sansa can be charged by any USB device or port that puts out sufficient current.
Dec 06, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
How do i change the battery
  1. Remove the cap over the USB plug and insert the unit into the USB port of a desktop or laptop computer. The computer will recognize the Sansa Express as a new hard disk drive.
  2. Locate the battery icon on the upper right of the screen. The battery icon will fill in with color as the unit charges. When the icon is filled in, the charge is complete. The unit will fully charge in about 3 hours as long as the desktop computer or laptop is powered on.
  3. Plug the unit into the USB port of a car or AC adapter and then plug the adapter into an AC outlet or an auto cigarette lighter socket, as the case may be. The Sansa Express will charge in about 3 hours.
Jul 17, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip is not Oning or charging
your scandisk memory " IC " has been Damage or not working
Or ur Battery has been lost please change ur batter more information [email protected]
Jun 29, 2009 | SanDisk Sansa Clip MP3 Player
Not being charged?
Sandisk Sansa Clip FAQ
The detection problem is addressed at that link.
Feb 06, 2009 | SanDisk Sansa Clip MP3 Player
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa clip
You need the latest firmware update from Sansa' website - may require a restart of computer after performing.
Apr 18, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e270 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Daniel Dollive
Daniel Dollive
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
