Philips HD4651 Electric Kettle Logo
Question about Philips HD4651 Electric Kettle
Doesn't switch on. Working fine until a couple of hours ago. Item is about 4 yrs old
L19wa monitor
It could be your sound cable is detached. it could be the inbuilt amplifier has failed.
We have a flotec well pump, less than a year old. The pump is working fine, and is primed. The switch doesn't appear to be working. Is this a difficult item to replace? Home Depot sells the pump and...
To replace the switch, shut off power, remove wires noting all wire locations.
You may have to relieve pressure in the system by using water until the surge tank is empty.
I'm not sure about that.
You do have to either remove the switch from the piping by unscrewing it or remove the piping from the switch by removing the connector and unscrewing the connector from the switch.
Assembly is the reverse. You should use teflon tape of dope on the screw connection below the switch.
The procedure should take about a half hour but you won't have any water during this time.
Gary
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
Craftsman gas blower (leaf) stops working after a couple of minutes. It was working fine up to a couple weeks ago. Now I start it, it works for almost two minutes as slows down until it stops. Then I have...
It could be something as simple as adjusting the carburetor. (if you have the adjusting tool) otherwise it sounds like there may be some debris in the carburetor. After running for a little while, it blocks the fuel jet. Then when you shut it off, it falls back somewhere in the carburetor. I'd suggest cleaning the carburetor and draining the fuel out and putting new gas in.
1helpful
2answers
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 • LG LFD25860
My windows media player has stopped working in laptop (4 yrs old)
try doing a system restore and check if it works fine note:- if you do a system restore all the recent applications will be lost and you will have to install it again.
Doesn not want to switch on
i have the same issue with mine and is only 4 months old / this is my second replacment-do u have a contact number for sony?
No water or ice from older kenmore side by side
You must pull fridge out the water valve is in the bottom back. Sounds like the valve is stuck open. You can Google your model# to find appliance parts to order new valve.
1helpful
APPLE IPHONE DEAD ZONE? ON KEYPAD 4 5 AND 6 WONT WORK (AND EVERYTHING ON THAT LEVEL!)
Try switching the phone off for a couple of hours. I had the same problem and tried everything, until I went to the movies and switched off the phone. When I came out and switched it on again it was working fine - incredible but true!
Top Philips Kitchen Appliances - Others Experts
Thomas Perkins
Thomas Perkins
ray gallant
Kardoc
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
