Question about Broderbund 3D Home Architect Deluxe 6 (383204) for PC
Can't raise walls - Broderbund 3D Home Architect Deluxe 6 (383204) for PC
Do you turn adjustment screw clockwise or counterclockwise to raise headlamp beam ?
Park 2 feet away from a wall and mark where the light is then adjust one way to see effect. Usually clockwise should raise the beam.
Oct 15, 2014 | 2001 Hyundai Elantra
Freezer gets fool of frost on walls of freezer only
if its both sides and the top... possible causes; door not sealing all the way around, icemaker stalling and heating raising temp in freezer, or the airflow is blocked.... if it is frosting only on the back wall its a defrost issue..... more info is needed to narrow this down for you
Oct 09, 2014 | Kenmore 64802 Top Freezer Refrigerator
My duravit toilet was hung too low and I'm trying to find a solution that doesn't require opening the wall
If you raise the toilet you will have to raise the plumbing so you have little choice.
Nov 05, 2013 | Duravit Home
This electric baseboard heater will be wallr mounted. Must it be raised and mounted above the floor or can it be set on the floor? Thanks, Mel
Mel, if you wave wall to wall carpeting, it should be about 1 1/2" off the carpeting. If you have hardwood floors 1/2" will suffice.
Hope this helped you.
Apr 05, 2011 | Heating & Cooling
Just moved in here and a painted wall has really bad troweling marks left on the wall. What would be the best way to deal with it, Just simply sand back to a level finish? Lazy plasterer.
Wash wall with TSP, and then fill all of the low spots with new drywall mud. It is TONS easier and less messy to raise all of the low spots. Faster too.
Jan 18, 2011 | Pool & Spa
Temperature on Refrigerator keeps raising
unplug it, move it from the wall for about 1 foot, clean behind, and plug again. Don't move it back , it has to stay at 1 foot from the wall and forever, this is called breathing distance.
Sep 27, 2009 | Refrigerators
Will the Jenn-Air JFI2089ATS accept 3/4" thick raised panels?
Hi: Raised panels, beveled are used all the time. Just check clearance of the thicker doors. Walls etc. Hope this helps, Jeff
May 30, 2009 | Jenn-Air JCD2295HES Side by Side...
How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
May 02, 2009 | Amana ATB2132ARQ 33" Top Freezer...
Dell926
Clear Carrier JamThese are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges.
Regards
Chittaranjan
Dec 14, 2008 | Dell 926 All-In-One InkJet Printer
Broderbund 3D Home Architect Deluxe 6 (383204) for PC Logo
Top Broderbund Computers & Internet Experts
Ekse
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
