Question about Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803
Tag heuer cau1110 chrono does not rest to zerp
5 Related Answers
Anonymous
SOURCE: adjust links on tag heuer watches
They push out. A tool can be bought from Harbor freight
Posted on Jun 14, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Anonymous
  • 3 Answers
SOURCE: Tag Heuer Formula 1 Mens watch
battery number 395!
Posted on Jan 02, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Tag Heuer Tiger Woods watch stops regularly
You should go back to the watch repair shop and ask for complete check-out of your watch. No watchmaker can return the watch to the customer without properly checking all the gearwork, timekeeping, battery power and all the features the watch has.
As your watch was serviced and the battery replacement took place, the executives of all the work done are responsible for all the faults your watch is having right now.
As watch repairs are quite expensive and time consuming, they (probably) will argue with you about this issue, but DO NOT give up, as these are YOUR consumer rights to ask for the job to be properly done (under warranty or paid by you). In case if you will be turned down, ask for FULL refund and find another shop.
If the repair shop is ready to undertake the job again, do not rush them, as the complete watch overhaul and check may take up to 6 weeks (this MUST be done at no any cost to you if you have the warranty or allready paid for the job).
P.S. I suspect that there is some fault in your watch geartrain, because if it is shooked or moved, the watch works, but when idle-it stops. That means the service of your watch was NOT DONE properly, and some failure or even dirt in geartrain was missed by the watchmaker (sometimes it happens- nobody is perfect!). This doesn't mean you have to agree with it, so, go and get your watch properly serviced and checked out.
Do not forget to rate, please.
Posted on Mar 09, 2009
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
Heuer caliber 15 (1975) chronograph second hand resetting.
Try pulling out winder to time setting mode and press your chrono button until it advances to the 12 then push winder back in
Sep 13, 2013 | Tag Heuer Watches
I have a tag with both chrono and digital readouts. I do not have access to the owners manual and want to sync the chrono and digital time displays. Any suggestions?
Their web site is not too helpful but if you go to http://www.tagheuer.com/login/?urlBack=/mytagheuer/index.lbl%3Flang%3Den, then you will be able to "become a member" and extract some useful information e.g. local stockists- who should be able to help.
Sep 21, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Need manual on operation of Tag Heuer ''Chrono'' watch . Leather band w/rose gold bezel.
I would contact Tag for this one. Most watch vendors will provide them at no cost. Be prepared to give them the #'s on the back of the watch to ID your watch.
Good luck.
Jul 23, 2010 | Tag Heuer Automatic Chronograph Series...
I have a tag heuer aquaracer crono automatic and i can hear it and feel it when its self winding is this normal?
this is normal if you didnt i would be worried..all automatics do this its the rota in the back theres no such thing as a silent automatic in the trade we call them swinging bricks..
Mar 23, 2010 | Tag Heuer Aquaracer Chrono Automatic...
Describe your tag heuer CN1111 replacement bezel Problem: The bezel came off & was lost
YOU have to buy new one. Will be costly. Check out e-Bay. Cheapest prices are there.
Feb 23, 2010 | Tag Heuer 2000 Exclusive Qtz Chrono...
My Tag Heuer chronograph will not reset to zero.
Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
Feb 11, 2010 | Tag Heuer Aquagraph CN211A wristwatch
Dont know how many time to wind it
until it begins to feel just slightly taunt,Do NOT over wind a wind-up wrist watch, if its a self winding you should just have to walk in it to wind it. here is a link to a pdf of your manual which has winding procedures, Good luck Jon click here
May 21, 2009 | Tag Heuer Aquaracer Chrono Automatic...
Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803 Logo
66 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
