Question about Akai LCT3701AD 37 in. LCD Television
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
From description it looks like a faulty inverter, I think that is the first part to test.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Apr 08, 2009
About fu101 , this is located on LCD controller board, that is the main controller board inside the TV.
Here the wiring diagram for the controller board.
Check the pictures below to find FU101:
This is the controller board:
This is the fues, on the left near to the squared IC on lower side of picture:
Note , if the TV has sound it is not Fu101, when the controller board fuse is gone, TV stays in standby.
You probably have a faulty inverter, just replace it.
Here is the inverter:
BACK LIGHT INVERTER SLAVE 6632L-0200D from AKAI LCT3701AD
The inverter is an high voltage board and testing it may be an hazard. To test an inverter you read voltages in and out. There is high voltage on volt out to lamp.
I had lost +24V on my power supply (Megmeet MLT386) and found F2 on the power supply blown out (3.15A). This was caused by a shorted QA2/QA2A (both are 9N50C FET transistors) After replacing these I found it still did not work, I found that four .47 ohm SMT resistors at R233 through R236 were blown open, i replaced them with a single .1 ohm 2W resisitor, I also had to replaced transistor QF1 (marked 2X4). After replacing all of these components, I restored the +24VDC and the tv.
Posted on Sep 15, 2009
can you see a back light on the tv if no it could be inverter board it self if yes the may be dry joints on the transformer on the inverterboard also check all the cable connections on the main board make sure the contacts are clean and fitted tightly good luck
Posted on Apr 13, 2009
Dear hpsaffold,
Can you test your TV with some type of alternative signal like a DVD or VHS tape and see if you get a picture with this method. Possible that you have a loose connection in the video circuit which got moved.
The memory chip may have gone bad, and will stay bad, here are the steps that will put it back into operation.
Using the remote that came with the television.
Posted on Apr 12, 2009
There are various circuits inside a television associated with height, width, colour, contrast, brightness, etc of the picture. More than likely the component (which could be one of many) is going to cost a few pence (cents), it's the call out charge for the techie thats going to cost.
If the television is newish or cost a lot then it may be worth repairing. Your choice..... cost of a call out charge + parts VERSUS new television with warranty
Its not the problem of any fu101 in your tv.its the problem of inverter board.and actually its not a big board.its like a thin rectangle chip board ogf green colour.
http://www.moniserv.com/doc/inverterrepair.html
click this link directly to know how the inverter boad looks.
now ------ What is a LCD Inverter board for?
A:--it is for lighting a LCD screen like a backlight .and because the backlight is off you dont see the picture.actually there is piocture on the screen.but there isno light so you cannot see the picture and this inverter board produces light to the screen to bring the picture on the screen.
(just for explaining you i mentioned this question /answer that why you need inverter board.)
please do rate the solution.thanks in advance.
thank you for using fixya.keep updated.
the exact number of the particular model which you have i dont have but i have few links which will definately help you to get the inverter board
link number 1
www.partstore.com
link number 2
www.radioshack.com
link number 3
www.bestbuy.com
keep update for further help.
thanks.please do accept the solution.
The problem is not the board but the colortube's CAPS need to be replaced.
you can get them from www.partstore.com or www.electronix.com
the caps are about $4 a cap. You will need a soldering iron to replace the caps
This occurs frequently on Akai and Samsung products.
Please take it to the store you bought from if still under warranty because you may not be able to get damaged parts elsewhere but from the manufacturer's authorised dealers. Dont dabble on the parts please.
Good luck.
Please rate this.
If the porblem is No display (just back lite) Audio works.
Replace a small fuse on 370wa02c board then picture works.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Posted on Apr 09, 2009
fu101 is a 10A/250V fuse
any fuse with the same values is suffice....
but however dont use a lower valued fuse....
u can order for fuses from
http://www.thefusecompany.com/index.php?inc=5
however i recommend u to ask a local electrician... he shud be having it
thank you
have a nice day
Feb 28, 2011 | Akai LCT2060 Television
May 07, 2010 | Akai LCT2060 Television
Apr 22, 2009 | Akai LCT3701AD 37 in. LCD Television
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Jan 05, 2009 | Akai LCT3701AD 37 in. LCD Television
Dec 17, 2008 | Akai LCT3701AD 37 in. LCD Television
Oct 01, 2008 | Akai LCT3701AD 37 in. LCD Television
Jan 03, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Nov 04, 2007 | LG 37LP1D 37 in. LCD Television
1,224 people viewed this question
where is this fuse locate
I look on the wiring I did not seen fu101 or on the schmatic
I look on the wiring diagram and a schmatic but could not find that fu101,this is for alct3701ad that has sound but no picture.
I order a invert board,I check the fuse i do read a 1.7 ohms, I am hope the invert board is the problem, I will let you know when this board come in
I brought the back light inverter slave 6632l0200d, I open the t.v up i do not see this board
I am try to find out where is theback inverter slave board 6632l-0200d.
I am still waiting on where is back light inverter slave 6632l-0200d is locate. this akai loct3701ad does not had no picture but had sound
I mam still look where is the back inverter board on this lct3701ad,,if I had aready brought this board, the free manual does not show where this board is locate on this t.v.
Seen like I just going around in a circle,look like i nheed go and purchyase a schmatic for ththis t.v. Seenj like no one can tell me where this inverter board is locate
the 6632l-0200d is not my inverter board for this lct3701ad, what is the cross reference for this inverter board,the board I has is 370wa02
to ginko, you told me toREPLACEA BACK LIGHT INVERTER SLAVE #6632L-200D,THE PROBLEM IS i DO NOT SEE WHERE THIS BOARD GO, I SEE THE 370WA02 IS THIS INVERTER DO i NEED TO SEND THE 6632L-0200DTHIS BOARD BACK TO jIMMY PART AND GET A 370WA02.i DID PUT A TINY PIECE OF WIRE ACROSS THE FUSE ON THE 370WA02 TUBE LIGHT UP BUT THERE NO SNOW OR PICTURE.
I ask a simple question where is the back light inverter slave 6632l-0200d locate on this lct3701ad that ginko told to buy, I see the inverter board 370wa02 ,where i put a short across both fuse but white screen but no picture.
