Onkyo TX-SR601 Receiver Logo
Question about Onkyo TX-SR601 Receiver
Onkyo TX-SR600 no right front speaker output
Having issue with my right speaker output on the Onkyo TX-SR600. Had a Bose speaker system, isolated the problem to the right speaker output on the Onkyo receiver. Please advise what could have cause this and what will be the fixed to resolve this issue? Thanks SparkyDc
Posted by Sparkydc on
  • 2 more comments
  • Anonymous Mar 25, 2008
    Onkyo TX-SR601 no left rear speaker output
  • Anonymous Apr 07, 2008
    Front right speaker does n't work. I have isolated it to the Onkyo TX-SR601 unit. I confirmed the problem with the white noise thst is produced when setting the audio levels per speaker output. I am wondering if it can be fixed by resetting the unit back to factory defaults or do I have hardware fault?? Ant assistance would be appreciated, regards John B
  • Anonymous Dec 13, 2008
    Same problem - SR601, front right speaker doesn't work. It is definitely the receiver, not the speaker. Let me know if anyone has a solution, or any insight! Thanks -V.
  • Anonymous Apr 03, 2009
    Rear right on TX SR506 for me. Taking it back to the shop to have it fixed under warranty...
3 Related Answers
Gurudristi
Sachin
  • 98 Answers
SOURCE: Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Posted on Mar 08, 2009
Grubhead
Grubhead
  • 5720 Answers
SOURCE: Can I play my ipod through my Onkyo TX-SR600 receiver?
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Posted on Mar 30, 2010
Testimonial: "Thanks so much. Great solution."
Anonymous
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
Posted on Jan 29, 2011
1helpful
Onkyo sr600 memory problem
I had the same problem with my TX-SR601 receiver.
Solution: I changed the capacitor C766 (100uF/6,3V) on the "DSP and main microprocessor" or "U1" board. This capacitor is responsible to keep the settings in the memory. It is directly next to the SRAM ICs (Q705-706) (type: CY7C1019BV/CV33-15VCT).
Now the receiver works properly again.
4answers
Bose Cinemateonnect
Hi lechap,
With the indulgence of IB4G2008 as per his last post Feb 13.....
If I figure your concerns right, they are:
1. You have an iPod on an Onkyo IPod dock that you want to connect to an Onkyo receiver TX-302;
2. You have an Onkyo receiver TX-302 that you want to power a set of Bose Cinemate speakers;
3. the connectors on some do not fit or are not the same;
4. you want to know what goes to where.
If I may suggest:
a. connect the L/R Audio Out of the Onkyo IPod dock to the L/R Audio IN of VIDEO 1 using a pair of RCA to RCA cable. Connect the S Video Out of the Onkyo IPod dock to the Video IN of VIDEO 1 using an S Video to RCA Video cable. Thereafter if you want to watch a movie or play music from your iPod, you need to choose Video 1 in the Onkyo receiver TX-302. You can of course choose any other VIDEO 1~3;572fcdc.jpg34ab5d3.jpg
b. all other source/devices may be connected similarly using the same scheme on any of the free VIDEO / AUDIO inputs
c. of course the MONITOR OUT goes to your TV or projector.
With respect to the Bose Cinemate, it would not be technically correct to connect the Bose Cinemate speakers straight to the speaker out of the Onkyo receiver TX-302. You need to install another set of speakers to the speaker outs of the Onkyo receiver. The Bose Cinamate system's TV AUDIO could be connected to the TAPE OUT (or the AUDIO L/R OUT of VIDEO 1)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
3helpful
The output to the front left channel is low
Try adjusting level calibration for the front left speaker under setup. This should solve your problem.
I have an Onkyo Hts - 580 Theater in a box sytem. Lately I noticed no output from the front left speaker, alos no output when test tone is used. Pkease help.
you might want to switch the speakers that youre using. e.g front left put it to front right and vice versa to isolate if the speaker has the issue or the amplifier terminal.
if the left speaker works on the other terminal then its a terminal issue.
Subwoofer not working on onkyo tx-sr600
Have you connected the Subwoofer out to the "Pre-out Subwoofer" on the left bottom corner jack(looking from the back)?
Have you set subwoofer out in the menu(under speaker settings or similar menu you will find all the channels that you have connected and here you should have "YES" for the subwoofer)?
HTH
2answers
Do all speakers need to have the same impedance? (Protect mode)
Amplifiers sometimes like to have "balanced loads" on them, and this may be the case with your unit, meaning yes, all the impedances should match.
Judging by the impedance numbers you provided, you should be all set. You really want to avoid having something like 2 ohms on the left side and 8 ohms on the right side - grossly imbalanced. I don't see any problems with what you're going to run.
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
3answers
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Top Onkyo Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
