Question about GE (PSS26MSRSS) Side by Side Refrigerator
In our 22 cu ft GE SxS fridge /freezer, the freezer fan speeds up and slows down frequently and creates a whoooing sound like a quiet hoot owl when reaching the peak speed of the speed up phase of the ebb and flow of fan speeds. Fridge/freezer works ok, it is just this unusual sound pattern that puzzles me. i know that the new models do have variable fan sppe but is this normal?
Posted by Earl Backman on
Anonymous
    Scholar:
  • 102 Answers
I have had some of these units making noises like this. One I found was leaking water down from the water inlet tube and in behind the ice maker and behind another panel that shoots up to the ice maker and building up behind that panel and causing a whistling sound. Removing the ice build up solved this one problem but couldn't find solution to the problem for the other. Dismissed it to change in the weather and expanding and contracting of the liner of the unit. Hope this helps.
Posted on Apr 11, 2009
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Trouble with freezer fan
Usually, yes. It should be very quiet, so if it sounds loud enough for you to hear it easily it may need replacement- if that fan breaks, everything in the freezer will melt.
Jul 25, 2009 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
SIDE BY SIDE Frig & freezer
hurlsdad.
Sounds like a noisy evaporator fan. Take the shelves out ot the freezer then take the panels on the back wall of the freezer off. The fan will be there. Then you will know for sure thats the source of the noise. When it is time to replace it...easy fix. (few screws) Here is an excellent source for the part..www.repairclinic.com. My favorite place for appliance parts.
hope this is helpful,
handiman518
Jan 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Noisy air flow problem, I think
the GE refrig has a variable speed fan motor controlled by the mother board located on teh rear of you refrig. the noise your hearing is the fan speed ramping up and down. if this noise is constant its possible the contoller on the mother board is bad and the board needs to be replaced. hope this helps...
Dec 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
479 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
