Boating Logo
Anonymous Posted on Apr 08, 2009
Trying to find were the empeller is location on 1983 omc stern drive. Got a repair manual for 87 model same as boat. But found out after buying the manual the engine is 83 model 6 cyl. Which was no help to me on this engine and drive. Thanks Dean
  • Anonymous Mar 21, 2014
    how do you separate the engine from the stern drive leg? can the leg stay on the boat
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Apr 13, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
31433
Points
150
The pump should be located on the shaft which requires you to take the drive off, be careful if you dont have a jack or hoist becasue it is heavy and hard to re-align
Need a repair manual for a 1997 larson 19ft with a 5.7 gl volvo penta with a SX Cobra out drive?pe
Boat manual yes
Larson Boat Owners Manuals PDF - Boat & Yacht manuals PDF
https://www.downloadboatmanuals.com > boats > larson
Larson Sport Boat Models Owner's Manual [ENG] PDF. Larson Sport Boat ... Larson Sport Owner's Manual.pdf ... I need a manual for my 1997 290 cabrio. #3.
Engine manual yes
https://www.volvopenta.com/service-and-support/your-engine/manuals-and-handbooks/
cobra outdrive yes $35
Repair Manual, OMC Inboard, Cobra, Cobra SX 86-98 ...
https://bpi.ebasicpower.com > omc-stern-drives-manuals
ebasicpower.com Repair Manual, OMC Inboard, Cobra, Cobra SX 86-98 [SEL3404] - Seloc ® Marine Repair Manual for OMC Inboard and Cobra Stern Drive ...
Videos
https://www.google.com/search?q=SX+Cobra+out+drive&rlz=1C1QJDB_enCA643CA644&oq=SX+Cobra+out+drive&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Serial where is the serial number for Gamefisher outboard motor I cannot find it for Gamefisher outboard motor where is it
Hello, Ron -
According to information in an owner's manual for a Gamefisher model # 225.581508 15" Transom and a model # 225.581498 20" Transom . . .
(Quote)
The model and serial numbers will be found on a decal attached to the port stern bracket.
(End quote)
Best wishes.
May 07, 2018 • Boating
Need a manual for yamaha 350 sterndrive maintance and service
Yamaha Outboard Stern Drive Repair Manuals
Bing search I came up with this but you may be able to find schematics or PDF manuals if you look for them or look for how to replace parts. Another useful idea is youtube video's on how to.
Sep 26, 2017 • Boating
1helpful
How to remove starter from 1983 30hp evinrude OMC
I just read up on the removal of your carb, It says to remove the flywheel to get more room, and then the carb, the left side bolt is harder to get to but it can be done. Only get 1/6 turn of the wrench, remove the fuel line, and be careful not to lose any throttle parts. Hope this helps.
Apr 15, 2010 • Boating
I have a 1987 Bayliner with a OMC Cobra stern drive with 2.3 liter four cylinder Ford engine. The alternator was changed out at some point, and the wrong one was installed. Some of the wire connectors...
Purple-white, AC on the alternator goes to the choke solenoid on carburettor
Orange ( thick cable ) is the charge cable, goes to the battery post on the startermotor
Purple is exc, positive from ignition key.
Red, sense, positive from the engine wire loom.
That's what I found
Aug 16, 2017 • Boating
1helpful
2answers
All the gear lube on my bravo III leaked out. The oil came out where the prop and the lower unit meet.
we had replaced the engine in our 87 4.3 star craft and when we put the omc cobra stern drive back in we now dont have foward gear, we have nuetral and reverse. could it be the linkage or could it be the shifter cable or any other idea's that could be the problem.
Location of impeller water pump on 1983 v-6 with a stern drive.
does the boat have a outdrive on the back of the boat? if so the impellar will be inthe bottom foot of the motor if not it will be in a housing toward the bottom of the motor belt driven with 2 two inch hoses to it but really need to know what kind of boat it is
Apr 08, 2009 • Boating
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
