I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
4 blinks is a fan error, check and see if the fans are clogged with dirt. Unplug the set then take the back off and get some canned air and blow the fans out.
I believe it is called the "light engine" is going bad. The Sony SXRD is NOTORIOUS for this going bad. So much so that there was a class action lawsuit that extended the warranty. My 50" SXRD went bad after 12 months. Because of the class action lawsuit, it was basically fixed for free.
IF SET HAS ERROR 9 THEN THE S1 and S2 board ARE PROBABLY THE REASON. DID YOU USE ORIGINAL SONY LAMPS ? GENERIC LAMPS (ESPECIALLY IN SONY) DON'T LAST. AND IS THE SET IN A CABINET ? I HAVE ALSO SEEN PROBLEMS WITH THE FANS GETTING DUSTY AND THE VENTS ON THE SIDE OF THE SET FILLED WITH DUST. DON..
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
