Sony KDL52W4100 Logo
Anonymous Posted on Aug 19, 2013
Hi I have a Sony Bravia KDL52W4100 manufactured in Oct. 2008. Today I noticed (2) horizontal pixel lines. They are both about 1/4 of the way down from the top. One is approx. 10" long and center on the screen. The other is 6" and on the right side. Both are about 1/8" wide. One day prior I hooked up a LG NB3532A sound bar to this TV. Is it a coincidence that I now have this problem?
5 Related Answers
Anonymous
  • 92 Answers
  • Posted on Feb 22, 2008
SOURCE: Vertical Lines of Sony Bravia 46
IT CAN BE FIXED BUT NOT BY YOU
BOARDS NEEDS TO BE REPLACED OR RIIBON CABLES NEED TO BE RESEATED. YOU CAN DEAL WITH A SERVICE COMPANY(NOT ALL ARE AS GOOD AND KNOWLEGABLE AS THE ONES YOUR READING HERE)
OR EXCHANGE IT
YOUR CALL
Anonymous
  • Posted on Nov 24, 2009
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
Anonymous
  • 68 Answers
  • Posted on Nov 28, 2009
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Anonymous
  • 4889 Answers
  • Posted on Aug 22, 2010
SOURCE: i have a Sony 52 inch bravia LCD TV KDL52W4100
You have a bad t-con board . Replacing it should resolve the issue. It is rather inexpensive too. If you want to do it yourself then let me know and I will help you find a replacement board.
Anonymous
  • Posted on Jan 12, 2011
SOURCE: my sony bravia kdl-46v3000 has a green line
It is the lcd panel failing, the same as mine. See link
infofrobetterbuys.blogspot.com
1helpful
2answers
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
hi if your tv is KLV-40V300A with 6x blink then the inverter board is defective replace the inverter board & tv will become ok
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
. Problem with Sony KDL52W4100 I've
Hello
You haven't specified anything about the picture condition of your Sony KDL52W4100. Will you please give me some more details about it. Do the vertical stripe moves acroos and washes out picture? Do you get well defined picture on the resr of the screen? As you know, this is an Email solution, and I've to get your Email address to post my solution. Sometimes, I may have to upload the service manual [schematic diagram]for your TV to get you more information about the fault, and the method for rectification. So, give me as much as details as you can. either give me your email iddress or send an Email to me at [email protected]. If I may have to upload the schematic diagram and service manual, I can't do it by this window, as this window does not allow me to uplaoad PDF files by it. I haven't placed my solution to your problem till yet. Get me the details I asked for, and help me to detect the actual fault with your tv. OK
Sony Bravia 52" 1080p LCD Full Pixel Mode Screen Problem
HI NORMALY WE ADJUST THE PICTURE THROUGH SIZE PLEASE GO TO PICTURE SIZE ADJUSTMENT AND ADJUST THE SIZE
THANKS
MUHAMMAD NASIR
7helpful
4answers
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
3helpful
2answers
I have a new Sony Bravia 46inch LCD tv with direct TV remote RC64R, what code can I use to get my remote to work? I've tried all the codes in the book.
i have a 46 inch sony bravia that i bought in 2007. recently i have noticed that the screen is showing horizontal lines (purple?) about that come and go. any advice would be greatly appreciated
2helpful
2answers
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
