Question about Konica Minolta Di1610 Copier
Dialta di1611 cof32
I have this problem and i have tried all the methods, but nothing works. Even the keyboard does not react to anything
2 Related Answers
Adorjani Laszlo
  • 1316 Answers
SOURCE: My Dialta Di2011 gives me an error code cof32 service call. What are the likely problems?
COF 32 ATDC sensor failure.Enter in the service mode select Then.rep.mode select printer mode select ATDC gain adjustment note the current value then clear the current value and change the value up or down.Ex: the current value = 150 clear and change to 154 ,make a few copy and if the error code not displayed is OK.If the error code is appaire clear the value and enter 132,make a feww copy,if OK you are resolved a problem.
Service mode entering:
press utility key-press metercount-press details(if apaire the details windows)-press Stop 0 0 Stop 0 1 (if appaure admin code press 00000000 ) select techn.rep.mode-printer etc.
Posted on Feb 07, 2013
Adorjani Laszlo
  • 1316 Answers
SOURCE: Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
Posted on Feb 19, 2013
Dialta di1611 error c0000
main motor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 08, 2014 | Konica Minolta Office Equipment & Supplies
Konica DiALTA Di1611 error message 2nd side door open although the door is closed.
Check and clean the sensors and actuators,verify the cable connection,verify if 5V appaire to red cable.
Apr 09, 2013 | Office Equipment & Supplies
Feb 19, 2013 | Konica Minolta Office Equipment & Supplies
Reset error code cof32 dialta minolta
on what model machine?
Jul 25, 2012 | Minolta Office Equipment & Supplies
Di350 error code cof32
Replace the image unit.
Jan 14, 2012 | Minolta DiALTA Di350 Laser Printer
My photocopier minolta di 183 is giving me error cof32 hw do l reset hv tried to run f8
Well need to replace the drum and developer running F8 with out changing the developer is not good, also make sure you clear the counter before replacing the drum and developer done toghter
Jul 25, 2011 | Minolta DiALTA Di183 Copier
Error code cof32
ATDC setting error - COF32, run F8 & use actual value, do not reduce setting value. open sie cover to reset.
Feb 14, 2011 | Konica Minolta DiALTA Di200 Copier
Code COF32
ATDC Toner issue, the image unit mite need to be replaced. The image unit is the unit you can pull out on th righthand side inside the machine with to handels on it
Jul 25, 2009 | Konica Minolta DiALTA Di200 Copier
Camera does not react
I quote: "A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen."
That means that there was a problem either with a LCD display or with ribbon cable.
Now:"I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out."
That means that the ribbon cable had probably shorted, now the camera may be furtherly damaged.
The camera must be disassembled to access the LCD and fix the problem.
The repair must be done by an experienced technician, as to access the LCD you need to remove both covers.
Jan 07, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Konica Minolta Di1610 Copier Logo
275 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
