under the hood. usually on the driver or passenger side. black plastic box. pop the lid off and it will have a map of the relays and fuses. hope this helps
Check under the carpet under the floor mat on the passenger side to see if it's wet you might have a leaky heater core if so just replace it and make sure the tubes are not rubbing against the body.
I have a 2005 f150 just notice that the driver and passenger side mats are wet. I had my windshield replace almost a year ago and went back recently to have them recheck the seal. What else could t be need help
shop vac the carpet dry then spray garden hose around both rear doors or around doors and see if you get wet or see a leak. Also spray under vehicle on both sides of car and check for leak.
Is it possible the water is actually coming from the A/C evaporator case, whose DRAIN IS CLOGGED ? The water produced by the A/C then leaks out of the case, down under the carpeting, then depending how vehicle is parked, can flow to the rear floors and carpet. Hope this helps
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
