I found your owner's manual here: http://nostalgiaelectrics.com/?wpfb_dl=155 Took a fast look through it and found no reset switch. However, there is an automatic lock. Just hit the cancel button and within 2 minutes, use your unit.
You can order new switches online. Just go to Nostalgia website. They'll have replacement switches. I'm trying to find the exterior handle that you use to empty the popcorn out of the kettle? I'm having a tough time finding it
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Here is a link to Nostalgia Electrics..Fill in their form and you can go from there. Here is the link... http://nostalgiaelectrics.com/default.asp?a=service copy and paste it into your browser or try to click on it..Hope this helps you..Wayne
