Samsung SyncMaster 920NW Monitor Logo
Anonymous Posted on Jul 21, 2017
Hi i just have a problem with my monitor hope to get an answer when i turn my pc on the monitor responds and work after a while 10min+ until it works it the power button keeps flashing then it works fine with no problem till next restart to pc i putted it on another computer same problem and if i take of the data cable and power it on get no message to insert data cable nothing it keep black with flashing power led
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Aug 25, 2008
SOURCE: No video output
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
Anonymous
  • 8637 Answers
  • Posted on Jan 09, 2009
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Jul 17, 2009
SOURCE: My Hanns-G HC194D LCD Monitor Takes Forever to come on
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Anonymous
  • 6 Answers
  • Posted on Mar 22, 2010
SOURCE: blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
digivisionm
  • 40 Answers
  • Posted on Aug 15, 2010
SOURCE: Problem with Samsung SyncMaster T200: After
try with new vga cable
My 2400 monitor start's up and work's for 10min. then flash's E14, i have cleaned everything possible and it just does the same thing, over again-E14, what might the problem be?
Sounds like the monitor or video card is going bad. I would try the monitor on another computer and see if it does the same thing. If it does you know the monitor has an issue. If it does not show the E14 then you know the problem is with the Video Card in the computer. To verify that it is the video card, just plug in another monitor and see if it does the same thing with the E14.
When fisrt turning computer on monitor shuts down ,have to keep turning it off and on until it finally stays on
Check the cable connections [VGA & power] and ensure they are properly connected.
Try switching the power cables with the PC and see how the monitor fairs.If it properly operates with the PC cable,then replace its cable.If there's no change, take the monitor to a repair shop and have it fixed.
Hope this helps.Thanks!
Please rate this answer.
Hi, I have a problem with my sony bravia KLV-32V400A SN6601740 the screen/monitor slowly darkens until it completely blacks out after 30-60 min but audio is still good. Turning it off for about 10min and...
Sounds like bad capacitors in the power module. Open it up and inspect the circuit boards for inflated or leaked capacitors. Replace with same parameters if any.
Hi I have a Gateway FHD2400 LCD monitor. Everything work fine but all buttons (inlude power and all select buttons) doesn't work.
If the control panel for the monitor does not respond there is no way to replace this. The monitor would have to be replaced if you desire that functionality.
However if the monitor turns on (without the need of the power button) and you do not need to adjust any of the settings then I would use the monitor until it could no longer serve its purpose.
Check the warranty status of the monitor and if it is under warranty you could get a replacement with a properly functioning control panel.
My monitor is not responding. I have a blank screen and my power led is flashing green, none of the front monitor buttons are responding, not even to turn of power. Cannot access menu as I have blank,...
Hi Cat, You can try removing the data cable of your monitor, the one connecting to the back of the tower/computer. If there are no issues on the monitor, normally you will be getting the power self test which is indicated by three vertical colors on the screen (Red, BLue, Green). If you dont see the power self test, it may be a problem with the monitor. YOu may want to try using a different monitor to isolate issue if available
3helpful
Hp w1907 Monitor problems
Sorry to her about your Monitor problems.
In the feature it would help to know what kind of monitor, the brand and model.
If this is a option, turn the monitor on, when you get image on the screen, press the menu key and scroll around until you find factory setting.
Restore to factory setting may bring the unit back and out of sleep status.
Try it, it may work..!!!
John Ray
[email protected]
Readers, please rate our information. Even if you disagree, it lets us know that you are responding and reading what we have taken the time to give you.
Thanks,
Delay in Monitor display once the system goes in sleep mode
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
1helpful
Monitor is in power safe mode
your resolution is set too high go into safe mode and turn the resolution to min and then play with it until it shows nothing push the space bar and leave the setting on that
1helpful
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
