Question about Canon NP 7130 Black and White Copier
I need a service manual for an Canon np7130
My company wants me to see if I can fix a Canon np7130 as I used to fix Canon copiers, but I am having trouble locating a copy or PDF of the manual.
Posted by jhalbstein on
  • 1 more comment
  • Anonymous May 11, 2010
    That's odd? I would have thought that service manuals, and technical support would be available free to anyone...hmmmm????
    Does your boss want you to wire the building too? better get a P/O for some extra fire extinguishers.
  • eric400 May 11, 2010
    what is the problem with it? you may not need the manual.
    what's your problem?
Anonymous
  • 3 Answers
I found a service manual for this model. If still need it let me know.
Posted on Aug 12, 2009
smith john
    Scholar:
    New Friend:
  • 134 Answers
Hello you can find canon np7130 service manual at below link:
http://goo.gl/hoX2CR
thanks
Posted on Nov 25, 2014
I canot download canon 5180 service manual but need the free one
sir service manuals are very confidential for company.
it is only availabe with authorized channel partner.
Apr 14, 2011 | Canon imageRUNNER C5180 Color Copier
HOPW DO I INSTALL TONER FOR THIS MODEL NP7130
From the left sideway of copier you will see small "handle",pull it up and open the copier in right pulling her up.
Then on right side of toner tube holder you will see the handle wich you need to pull in anti clockvise direction, to remove toner unit from drum.
Rotate the toner tube clockvise and pull toward you.
Insert new tube, hold tube and pull out toner seal tape all the way out, rotate anti clockvise until its locked.Return handle in first position and close cover of copier.
Aug 04, 2010 | Canon NP 7130 Black and White Copier
Error e000008-0001 system will not reboot
Hi, E008 is a fixing roller service life error.
You would have to have the fixing assy repaired or replaced,
I have a good used one contact me if you are interested
[email protected]
If you need the service manual to troubleshoot it yourself you can get it here
http://www.techmanualarchives.com/canon-ir-c3100_3170-service-amp-parts-manual-25168.html
Feb 05, 2010 | Canon ImageRunner C-3170U Copier
Canon np7130 copier
Most likely when you make a copy you don't see the light scanning the paper, you can try this with the lid open to make sure. the Sacnning lamp is blown, need to replace
Jul 14, 2008 | Canon NP 7130 Black and White Copier
Black Copies
It could be a bad voltage board, which is not supplying enough power to the lamp.
Jun 30, 2008 | Canon NP 7130 Black and White Copier
NP7130 drum problem
hi im jules_09,you should not use compatible consumables for the copier sometime np7130 copier are nasty specially with opc drum,if the copy is blnk the problem is in the high voltage unit or in the transfer unit and drum charge unit you might have the wrong process replacing the drum.re install the drum then try it again .
Dec 02, 2007 | Canon NP 7130 Black and White Copier
Canon NP7130 copier
Make sure that the black plastic arm just to the right of the gray drum release handle is in the proper position. This arm sometimes gets knocked out of position when engaging the tube of new toner. When the copier is clammed closed, this will sometimes come down on the right side of the post on the bottom front cover. This will move the developer far enough away from the drum to make blank copies. Hope this helps.
Nov 12, 2007 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
987 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
