Motorola Mobility V220 Logo
danny marsden Posted on Sep 06, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power hi ive got a v220 and its turning on but the battery is fully charged and is the right type for the phone ... it turns on for 30 seconds but thats when i take the rear casing off and press hard on the battery what do i do?
Anonymous
Level 3:
  • Master 626 Answers
  • Posted on Sep 06, 2007
Anonymous
Master
Level 3:
Answers
626
Questions
0
Helped
367405
Points
1382
Check the contacts where the battery connects, if they have any corrosion (green or rust) on it, you should clean them. Toothbrush and alcohol should suffice. Otherwise, check the "water indicator" decal on the phone behind the battery. It should be white, if its gotten wet, it will turn red. Best of Luck.
2answers
My phone is not working, Cannot turn it on or charge battery.
Fix an Android device that won't charge or turn on If your Android phone or tablet isn't starting, won't turn on, has a black or blank screen or turns on but immediately turns off, try these steps to fix the issue.
First, try holding down your device's power button for five to seven seconds. This usually restarts a device.
Step 1: Troubleshoot your cable, charger, wall socket & case
  1. Use the charger and cable that came with your device. To check that the charger and cable are working, try them with another device.
  2. Check that the cable is securely connected to the charger and to your device. Check that there's nothing in your device's port, such as dust or lint.
  3. Plug the charger into a wall socket. To check that the outlet is working, plug in something else, like a lamp.
  4. Check that no accessories, such as cases or battery packs, cover your device's sensors or press its buttons.
Step 2: Troubleshoot your battery charge Within one minute after you've plugged in your Android device with a working cable, charger and wall socket:
  • If you see a battery icon, your phone is powered off and is charging. You can restart right away.
  • If you see a red light, your battery is fully discharged. If the red light is flashing, there isn't enough power to turn on. Charge your phone for at least 30 minutes before restarting.
To restart your phone, press and hold the power button for a few seconds. Then, on your screen, tap Restart . (If you don't see 'Restart', press and hold the power button for about 30 seconds, until your phone restarts.)
Step 3: Troubleshoot your screen If you don't see a battery icon or red light after you plug in your Android device, the issue could be with your screen.
  1. Press the power button for about 30 seconds.
  2. Wait about 2 minutes.
  3. Make your phone ring. You can call it from another phone or use Find My Device.
Mar 10, 2019 • Cell Phones
tip
HTC increase Desire battery life.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
on Jul 11, 2011 • Cell Phones
I bought the product new,ive charged the phone but it will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Phone won't turn on
5.Wait 10 seconds.
Step
Thanks
Phone wont turn on
5.Wait 10 seconds.
Step
Thanks
Tx-26lxd70a tv wont turn on
5.Wait 10 seconds.
Step
Thanks
I want to k550i formatting number
Below are some helpful tips for what to do if you can't turn your phone on. Be sure to try each one to determine the nature of the problem.
  • First, make sure your battery is fully charged. If the battery is drained out, it may take up to 30 minutes of charging before the battery-charging icon appears on the screen.
  • Press the On/off key for a minimum of 10 seconds to turn the phone on.
  • If your phone has a memory card, remove the memory card and try to power the phone on. If the phone turns on, you might need a new memory card.
3helpful
2answers
Motorola razor not powering on
is this the first time you are trying to use the phone? if so, (i have this phone so if you have any more problems just ask), hold down the red phone button (the button to put the phone down) for as long as it takes to turnn it on (usually about 10 seconds).
if this isn't the first time you are using it and it has worked before, charge it fully, then take the battery out for 30 seconds and put it back in. if none of this works, take it back to the shop and ask for a replacement.
1helpful
Just bought motorola v220
If the battery is charged, you should just need to hold down the red (end call) key for a few seconds and the phone should power up.
Top Motorola Mobility Cell Phones Experts
ADMIN Eric
ADMIN Eric
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
