Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Question about Canon PIXMA MP160 All-In-One InkJet Printer
My printer ink absober was full. my printer display e27 code. what can i do?
Posted by examsksat on
  • 1 more comment
  • Anonymous Apr 09, 2009
    I have the same problem and am told it is cheaper to buy a new printer than to have the absorber replaced. Is there a way around this?
  • Anonymous Apr 13, 2009
    CRAB PRIINTER
  • Anonymous Apr 23, 2009
    Resetting ink absorber counter problem. How do you get the sides off the printer? Canon MX 310 Printer!!!!!!!!!!
Anonymous
  • 28 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-9
Posted on Sep 04, 2009
JDTec
    An expert that gotĀ 20 achievements.
    An expert that gotĀ 10 achievements.
  • Canon Master
  • 4,338 Answers
Try a reset:
MP150/160 resetting errors
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset .
5 times Orange Destination setting
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 13, 2009
2 Related Answers
Anonymous
  • 14 Answers
SOURCE: Error code E27
take out long black sponge under print head. wash, dry, replace.
Posted on Apr 20, 2009
arjoon
KENTRONICS
  • 113 Answers
SOURCE: absober waste ink is full. Pls help. error code
you need to replace the absorber waste ink pad and service the printer
Posted on Nov 17, 2009
Testimonial: "Thank you. Looks like it is not a DIY job."
tip
True guide to reset ink tank absober full on canon mp140
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blinking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Ok world...Good luck
hopefully this can helped to solve your problems.
Thanks.
please leave your evaluation.
Extra download ====> Fix_IP1000InkOverFlow
Hello I would like to change b/w and color ink on my Canon MP150 Printer. Unfortunately the role where the two inks are is not moving. How can I change it? On display it stands E! Thanks and...
Hi.
usually due to problems you may have absober waste ink full, it will cause your alarm LED blinking and E27 error appears on the LCD screen and failed to move the printer ink. refer to the link below to learn how to cope.
CLICK HERE
please accept and leave your rating if it helps resolve your problem.
Regards
1helpful
2answers
My printer displayed: the ink absorber is full. i then cleaned the absober but its now not displaying anything. so how best do i solve this problem?
For Canon MP190 ONLY it worked that software but I used a software named Resetter Canon MP198. First put the printer in service mode. Press and hold the RESUME button (Is the red one ), then press and hold the POWER button, wich became green.
While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times. Ast the first press the green power button turns off and a orange led turns on. At the second press the orange led turns off and the power became green. Now the printer is in Service Mode. So with printer conected to PCstart the software and reset the ink absorber level. It worked for me.
3answers
Ink absorber almost full
Need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> push your printer cartridge door switch with pen or anything can press door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
Hope this guide can help fix your problems
Extra download
Fixwasteinkabsoberflowip1000
There is a message that ink absorber is full and contact tne service centre.
Service tool 2
> close open door
Extra download
Fixwasteinkoverflowip1000
1helpful
My canon ip1980 appears error 5100 on my display i will replace my data strip but the problem still occurs. What should i do. Tnx
This problem is between waste ink absober full and ink cartridge.
Firstly your need to reset waste ink absober full.
Service tool 2
> push your printer cartridge door switch with pen or anything can press that door swith.
> close open door
IF after reset your waste ink absober full, problems still apppear error5100
> change your ink cartridge with the working cartridge
usually error e5100 due tow problems above
Extra download
3helpful
GETTING ERROR CODE E27, INK ABSORBER FULL
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
3helpful
Absober waste ink is full. Pls help. error code
15helpful
4answers
Error code E27
Clive
Clive
old marine
old marine
