Question about HP OfficeJet 6110 All-In-One InkJet Printer
How do I change the font size on my 5600 All-in-One printer
Posted by bbaczuk on
Anonymous
  • 78 Answers
You need to change the font size in your document not on the printer.
Posted on Apr 07, 2009
2 Related Answers
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: font size
Probably the monitor-chip on the board is working inproperly.
Consult the vendor or manufacuturer.
But before this, you may download new monitor driver from the manufacturer.
Posted on Jan 11, 2009
Anonymous
SOURCE: change font size on lexmark printer
How do I change the font size on a lexmark X3350?
Posted on Aug 06, 2009
How to change font size on my printer
font size, is done in the printer menu, pop up under size
Mar 03, 2015 | Canon MX882 All-In-One InkJet Printer
How do I increase the font size on my hp printer when printing from my computer
The font size is usually controlled by the properties of the page you are trying to print. Try increasing the size of the font on the file.
Feb 17, 2015 | HP Office Equipment & Supplies
How to change the font size in ZEBRA 220Xi4
You would change the font size in the label design software that you are using. Click on the text box and then adjust the font and font size.
Jul 08, 2011 | Zebra 220Xi4 Thermal Label Printer
How do you increase/change font size on labeler?
To set the font size
1. Press Format
2. Select Font Size and press }.OK
3. Select the desired font size and press }.OK
The font size indicator on the display changes as you select font sizes.
Jun 22, 2011 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
How can change Font Size 11 into12
Under MS Word 2007 simply:
- In the menu bar you see the font name and beside it is the font size, for example, 11.
- Highlight some text in your document.
- Now click on the drop down arrow by font size and slowly scroll through the sizes.
- The selected text will change sizes as you move through the size listing.
- In this way you can get exactly the right font size for your document.
Jan 04, 2010 | Epson FX 1170 Matrix Printer
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
Mar 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to change font size on officejet 6110 printer
you determine the font size via your computer. You can change font sizes on any document typed or received as long as the received document is not 'read only'
Changing font size
Try changing the font size in Notepad/Wordpad/Microsoft Word. If that fails, then go to the settings on your printer, and it should have a default size on their that you can change. Change it to 0 and it will go to all sizes allowed.
Hope this helped -CA
Nov 08, 2008 | Brother Multi-Function Center MFC-240C...
Change font size on lexmark printer
Oct 18, 2008 | Office Equipment & Supplies
Brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Aug 02, 2007 | Brother HL-2040 Laser Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
93 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
