If the machine does not vibrate or makes loud noises, nothing is wront with your shocks. The spin has often to do with worn motor brushes. Giving you below a general remedy for 'no spin'; might find it helpful.
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
My Equator also doesn't get up to speed. I love this machine and want to know what options I have to solve this problem
