Question about Pride Mobility Products Health & Beauty
I need a manual for the Celebrity Pride Model E675
5 Related Answers
my-mobility
my-mobility
  • 9 Answers
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
Posted on Jun 22, 2009
oregoon
  • 175 Answers
SOURCE: pride celebrity deluxe comfortcoach 1v problem-
Usually when a scooter dies, there is an event that preceded the dead state that caused the fault. What were you doing before it went dead?
The biggest culprit for scooters and power chairs is moisture. With a scooter, there are two components most susceptible. One is located inside the top of the tiller and it is an electonics board about 6"x4" in size. If you had the scooter out in the rain without protection over the tiller, water can encroach into this area and short the board. Or, a coke or coffee spill can short it. There's a fuse on the board and if it is blown, then likely the board is shot as the fuse merely keeps the tiller from going into a total meltdown in the event of a short. Boards run about $25.00 to $45.00 to replace. Inspect it and look for any signs of overheating or corrosive buil-up and see if the fuse has blown.
The second component is located under the shroud beneath the seat. It is a small metal box which is the power control module and it controls all of the operations of the scooter. It has several wires going into and coming out of it (on-board chargers for some scooters will only have one wire going in and one coming out, sometimes two). These boxes are water resistant, but are susceptible to damage if the scooter has been run through a puddle and a lot of water has splashed up onto it. These are several hundred dollars to replace, but first check all of the fuses coming off the batteries that will lead from the battery to this control box and insure that it isn't a blown fuse. These fuses generally don't blow unless the scooter was operated beyond its capabilities, like driving it in sand, mud or other unstable terrain that puts an enormous strain on the motor and pulling a lot of juice from the batteries. Finally, check all of the connections that clip together. Don't rely on a visual inspection, take them apart, and reconnect them all to insure a good, tight fit.
Hope this helps.
Posted on Aug 28, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Posted on Oct 12, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: i am looking for a wiring diagram for the charger
hi ,I don't have access to the wiring diagram however I worked on most scooters so can I ask what the problem is , has the wiring loom got damaged ? if so please tell me the name of the motor contoller under the seat a blue or black box. I have rewired over 200 scooters so it not a issue. Not one failure.
Please let me know how you get on.
Regards
GeWiz.
Posted on Dec 31, 2009
Neil Wood
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
What size batteries go into a celebrity x mobility scooter with four wheels
Pride Celebrity SC400 SC4001 Battery Replacement Kit
There is technical support offered at the Pride Go Go website. The site above simply offers a replacement. Further specifications may be obtained from them or a manual.
Pride Mobility CELEBRITY Owner Manual
Aug 12, 2017 | Health & Beauty
HUSBAND FLIPPED HIS PRIDE CELEBRITY X SCOOTER STOOD IT STRAIT UP IN THE AIR.NOW NOT WORKING.5 FLASHES
Five beeps? Maybe it's not the same as my Celebrity XL8 but my instruction manual talks of a 1+4 beep warning meaning low battery charge. It also suggests checking that the wiring harness connectors are all fully connected - that would include the battery terminals of course. If your hubby managed to do a wheelie this sounds a strong possibility if the batteries were dislodged. Anyway, I attach the page from my Celebrity XL8 manual, you can find other Celebrity manuals online. My congratulations to your husband, I've yet to master wheelies!
Jun 13, 2017 | Pride Health & Beauty
Where can i get wiring or troubleshooting manual or pdf for my celebrity x 4401?
Here is a link for the Pride manuals.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
Oct 12, 2014 | Pride Mobility Products Health & Beauty
Need a service manual for Celebrity XL Pride mobility scooter
Goto pridemobility.com. It's the American site as pride is an American product. User manuals and spec sheets etc available to download
Sep 09, 2014 | Pride Celebrity Xl 4 Wheel Scooter
What do pride celebrity x sport error codes mean
Download the otherwise fairly useless Pride owner's manual, the beeper codes are listed there.
Jun 12, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Turn key on pride celebrity scooter. everything looks normal-all lights on does not run. i am a mobility tech
As a mobility tech you can log onto the Pride Service website and access the technical troubleshooting guides. There is a good one for the Celebrity X . If your company has a dealer account with Pride you can go on-line and request a log-in for tech/dealer access for illustrated parts breakdowns,parts ordering, service manuals and trouble-shooting guides etc. It may take 24 hours for the log-in approval but if you call in the AM they may be able to expedite your request. iPride and Pride service are very effective in providing all the information you will need. Hope this helps.
Dec 22, 2010 | Pride Mobility Products Pride Mobility...
I am looking for a wiring diagram for the charger on a celebrity scooter legend mod# e675
Regards
GeWiz.
Dec 18, 2009 | Pride New Mobility Celebrity 3 wheel...
Need manual for celebrity x mobilty scooter
Go to cheapest-scooters.co.uk Then click on photo of celebrity x sport mobility scooter.Then scroll down page and click link to download owners manual. Hope this was helpful?
Sep 24, 2009 | Pride Mobility Products Celebrity X - 3...
Health & Beauty Logo
245 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
