Question about JVC AV-27530 27" TV
No picture on dvd but picture on tv only sound comes out on dvd
Need picture to come through dvd only tv picture comes up sound only comes through from dvd to tv
Posted by fishogpower on
Anonymous
  • 700 Answers
Could you try to set your channel to 2,3, or 5 when viewing video from dvd. Or try search which channel will the video and audio will sync in tune. I think this is an old tv.
Hope this one helps.
Posted on Apr 26, 2009
Have a 36 inch vizio flat screen it started about four days ago.When i switch from watching a movie on DVd back to regular picture on component 2 no picture is coming up tried chanel 3 an d4 still no...
It sounds like you aren't cycling fully.
It sounds like you are on the TV (RF/Cable) input, then you switch input to Component 1 (for your DVD) and watch the DVD, then hit the input selector again, switching it to Component 2...you need to keep switching the input until you are back on the TV / Cable input.
Jul 11, 2011 | Televison & Video
When hooking up to a new tv, the sound no longer
Hi
This all depends on how you connected the two. If you used the component cables then you've forgotten the audio cables. If you're using an s-cable then you've bent a pin or the connector is not centered. If you're using an Html connector then the cable may be bad but my money is on the DVD player being bad.
Jun 05, 2010 | Panasonic DMR-E75V DVD Player/VCR
We have a picture but no sound, it is hooked up to our surround system and the dvd and radio work and we have sound coming out of the speakers but no tv sound....help
Try switching the external/internal speaker switch on the back of the tv to internal. This way you should at least get sound (from the TV not the sound system) when you change the volume of the TV itself.
Explain your set up if you need more help. By that I mean what do you have hooked to the TV and sound system, Satellite or digital cable box DVD ?
Make a note of where all the inputs to the sound system come from.
Dec 04, 2009 | RCA P56830BL 56" Rear Projection...
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
SharpVision Model 64LHP4000: Hear a clicking sound coming from back of tv, solid red light, on front, comes on but no picture or sound.
Is your antenna connected or you cable satellite hook up to the TV? you need a signal of some sort to activate the TV circuits. Try a vcr or dvd player hooked to the set put in a tape or a dvd!!
Jun 30, 2009 | Sharp Televison & Video
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Dec 09, 2008 | Televison & Video
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
No picture when I turn the tv on only sound
TRY CALLING BEST BUY'S GEEK SQUAD TO COME FOR A IN-HOME REPAIR SERVICE CALL AND THEY WILL FIX YOUR PROBLEM!
Dec 14, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
JVC AV-27530 27" TV Logo
199 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
