Question about Vizio 42 in. LCD TV
Picture keeps getting all scrambled
Most of the time the picture is perfectly fine, but from time to time the picture will start to scramble and get worse and worse or all the black will fill up with red lines and the only way to make it go away is to turn the tv off and back on again. I thought maybe it was a cable box problem but then it happened while i was watching a dvd.
  • 34 Answers
Sounds like a problem with the main board and or av connector cord. contact vizio and let them know you are seeing some red pixelation. some parts on vizios carry lifetime warranties, it has been my experience that this is a covered issue. hope this helps.
Posted on Apr 08, 2009
6ya staff
SOURCE:
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Hitachi ultravision digital projection TV. The picture scrambles horizontally. The colors look fine. The picture is great for the first few minutes the TV is on, then it scrambles. I've unplugged it,
This sounds like a heating problem..Either there is something keeping the heat inside the cabinet like stuff on top of the cooling vents (also on the sides and bottom) or there is dust inside. Blow the thing clean with clean, dry compressed air inside the cabinet.
Jan 07, 2013 | Televison & Video
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
Picture and menus are scrambled or black, but sound is fine
t-con boad failed the company is out of business try shop jimmy.com
Sep 17, 2009 | Televison & Video
Picture is scrambled when first turned on
connect a dvd up,and see if you still have the problem with the dvd.i thank you have a proplem with your cable or antenna.
Aug 19, 2009 | Toshiba Televison & Video
Scrambled LCD tv picture
I would think its a T-con bard fault its the main board for the screen over time they ware out from heat. this control the picture for the screen. they can go in many ways, black screen mixed or shadows even star screen and scramble type screen. and white lines and even half working only.
Jun 07, 2017 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
- Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
Mar 13, 2009 | Toshiba Televison & Video
Problems at start
Please email me the model number for the tv so i can better assist you.
Thanks,
Tim Nolan
[email protected]
Oct 09, 2008 | Sony KP-53HS30 53" Rear Projection...
W2606c picture scrambled
Um...well when mine does that i unplug it and hold the power button for ten seconds and then plug it back in. Always works for me ;-) hope it works for u.
Aug 19, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
Vizio 42 in. LCD TV Logo
900 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
