SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
SOURCE: will PGI-5BK and BCI-3E ink tanks fit in the MX700?
Ink Tanks:
PGI-5BK, CLI-8C/CLI-8M/CLI-8Y
According to the canon australia website these are the inks for the MX700
SOURCE: canon MX700 cannot detect remaining ink level
Try to run the reset tool for canon printers which will reset the printer.
http://www.ziddu.com/download/2620692/IPtools.zip.html
SOURCE: Black ink does not print. Color works fine.
Here is the maual for your printer:
http://gdlp01.c-wss.com/gds/0300000450/mx700_qsg_us_v1.pdf
Sounds to me like the printheads are either clogged or the printhead itself it bad. Page 86 of the manual explains what to do. Print the nozzle head check pattern, if the black is missing then go ahead and go thru the print head cleaning. This should start unclogging the printhead.
If you still dont have black then go ahead and do a deep print head cleaning.and if you still don't have any black ink coming out onto the paper then for sure the printhead is bad and would need to be replaced.
At that point, contact Canon and get the part number from them so you can shop around and find it at a good price.
SOURCE: how to refilling canon cartridge mx700and reset
What needs to be reset is the kill chip on each of the individual cartridges. If you buy from a reputable refiller they will have equipment that is able to do this. A refill will not work unless this is done.
