For2001 Ford Mustang 3.8L SFI 6cyl engine, with which your specific vehicle is equipped, can be most
easily identified by the Vehicle Identification Number (VIN), located on
either the VIN tag, mounted in the upper left-hand corner of the
instrument panel, or on the vehicle certification label, located on the
driver-s side door pillar. The engine identifying code is the 8th digit
of the VIN. The engine VIN codes are as follows:
FIG: Engine identification codes may also be found on a label affixed to the left side rocker arm cover
2000 Dodge Intrepid 2.7L SFI DOHC 6cyl Repair Guide The Flasher is located front seating area, driver side, under left hand side
of instrument panel between junction block and brake
pedal.
2000 Pontiac Grand Prix 3.1L SFI OHV 6cyl The Oxygen Sensor is located
under hood, center, rear engine area, above exhaust
pipe flange, mounted in exhaust manifold.
Application:
Number one
Fig. Locations of the heated oxygen sensors in the exhaust
manifold and the three-way catalytic converter-3.4L (VIN E) engine
shown, others similar
