LEM Products lem Stainless Steel Dehydrator 778 Logo
Anonymous Posted on Aug 17, 2013
I have a LEM 778 - 10 tray stainless steel food dehydrator and would like to know if I can put the stainless steel shelves into a dishwasher to clean.
Sam Oldman
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Sep 19, 2013
Sam Oldman
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2886
Points
12
tip
What is Food Dehydration all About
Food dehydration is a very long standing way of preserving food. In modern times, food dehydration machines have been developed, allowing people to dehydrate their food at home.
Dehydrators work by removing the moisture from food thus allowing them to last for much longer.
Because the water is removed at a very low temperature, the nutrients and enzymens of the food are not destroyed and that's why dehydrated food is seen as part of the healthy food movement.
How do you use a food dehydrator?
1. Wash and dry the foods you want to dehydrate
2. Arrange the slices on trays. Try and avoid overlapping.
3. Set the temperature using the guide. Generally the lower the temperature the greater the preservation of vitamins and nutrients.
4. Keep an eye on the trays, turning them in the dehydrator.
5. It can take anything from a couple of hours up to a day to dehydrate food, depending on the moisture levels.
6. When the food is ready store it in airtight plastic bags or containers.
Enjoy experimenting with your food dehydrator. It's fun for kids as well and is a great way of preserving fruit and vegetables when you've overbought or can see food would otherwise go to waste.
Where is the filter on a kitchenaid dishwasher#kuds35fxss9 ?
There is a water inlet filter at the inlet valve. The dishwasher has what is known as a food disposer waste system. It has stainless steel blades which actually grind the food particles and then drains them with the water.
I have a LEM 778 10 try stainless steel food dehydrator the machine when running runs okay until the end when product is almost dry then the fan motor turns off and still hear the motor running. Heat and...
Most of these stainless dehydrators have a cheap timer which uses plastic gears turned by an electric motor to operate the machine. After being on for a while the whole timer will heat up and the gears unside will begin deflecting and failing. When this happens the only thing to do is wait for it to cool down and see if it works again. Eventually it will fail completely and the machine will jus tstart shutting down halfway through cooking.
It is possible to bypass the timer and use an outlet timer, but each model of machine is wired slightly differently. You would have to consult a knowledgeable electrician.
There are newer models on the market which have digital timers. These work muuuuch better, but the fa
10 tray dehydrator - Airite need an instruction manual
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
2helpful
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
Food on dishes
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
Food left on dishes
Scrape your dishes of food.  Dishwashers remove whatever is left.
13helpful
Lost manual -The Deni 5 Tray Food Dehydrator-
Hi - You can download the manual by clicking the link underlined in blue below:
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Top LEM Products Kitchen Appliances - Others Experts
john h
Are you a LEM Products Kitchen Appliances - Other Expert? Answer questions, earn points and help others
