Honeywell Air Purifier. True HEPA Air Purifier 17007-HD Logo
Question about Honeywell Air Purifier. True HEPA Air Purifier 17007-HD
Honey well air purifier 17007 fuse blew. how to repair
Posted by George Carofino on
JaesonK
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
The fuse is located inside the control panel. It is soldered to the circuit board, not mounted in a typical fuse holder. You will need a Philips screwdriver to disassemble the unit. You will need a soldering iron & solder to remove the fuse and replace it. You may want to a multi-meter to check the fuse. If the unit just stopped working, it could be a number of other issues than the fuse. The starter capacitor for the motor could be dead or some other issue. You must take precautions against electrical shock. You may need a technician to safely perform some repairs.
Posted on Jun 04, 2019
Can you replace the control unit on a Honeywell air purifier model no.17007-HD
Normally Honeywell has NO replacement parts. Run it as is, then throw it away.
My honey wel air purifier won't even light up I caned the permanent filter and put in new. When I plug in it it and I turn the start button I get nothing is the motor burnt out or whet
Try placing the filter in again. Also unplug the unit an wait a few seconds to reset. Plug it back in. I am guessing you got wrong filter or it is not placed in correctly.
Canunit will not turn on
If this is a Fresh Air, check the fuse. If the fuse is good, the main circuit board may have failed, Call (336) 499-2505 and they can tell you where to send it for repair. Tell them you were on Fixya.com.
Fresh air 2, blue light goes out, fan still works, reads
If the light goes out, it is time to replace the bulb AND the bulb starter. They need to be replaced every two years. Beyond that, they are an expensive night light. If you need to order one, call (336) 499-2505. Also ask for supplemental cleaning instructions since the original instructions are incomplete.
2helpful
I HAVE 2 MODEL SI861 IONIC BREEZE UNITS. I BELIEVE I BLEW THE FUSES BUT CANNOT FIND OUT WHERE THEY ARE LOCATED. CAN ANYONE PLEASE HELP. THANK YOU.
There may be a thermal fuse in the vicinity of the motor, it may be held to the motor, there will also be one wrapped in the windings just for the motor, or it may just be covered with a section of black shrink wrap. It will have a current rating and a temperature rating as well. Otherwise look closely on the control circuit board as a "pico fuse" really small fuse can be there. It's only indicator will be a current rating like "2A"
My unit has been in storage and I have just now cleaned it and put it back together, but it won't come one...how do I know if the fuse is needing replacement.
You power down, take the fuse out, and put the leads of a DVM across it (or have your local prefilter supply place use their DVM.) If the thing blew and therefore reads OL (open line, as opposed to a closed circuit) then you need a new good one. You can't always see metal deposits and a break in the fuse wire.
1helpful
WHAT TYPE OF FUSE THAT MY LIVING AIR USE? The model number is 243525. I am trying to get it work in Germany. I do have the right converter but I just blew the fuse. HELP>
1.6 amp for Fresh Air. They do have a 1 amp for other units. If you take it in, any radio parts store will have them, very popular fuse here in the states.
I lost neutral on the electrical service and my cleaner no longer works, i changed the fuse that had blown, but when i turned the filter on it simply blew the new fuse
Blowing a new fuse would indicate that there is some component of the machine which was damaged. The fuse is a safety device which keeps electricity from flowing through defective wiring.
You can visually inspect the machine to see if there are any wires, connections, or components that appear to be damaged, burned, loose, or broken. The plates need to be perfect, without cracks, burned spots, loose mucilage, broken screens, etc. The contact fingers should be screwed firmly in place, and they should press firmly against the screen part of the plate.
If you can detect and then repair any of the above defects, and if the machine still blows the fuse, you can assume that the problem is deeper in the machine and it needs professional help! Unfortunately, Vollara (formerly EcoQuest) no longer makes or repairs the Flair. You can contact Vollara customer service 800-989-2299 to locate a dealer in your area; they may have another machine or know where you could get one. They may also know of someone who could repair it for you.
Sharper image ionic breeze quadra air purifyer
I believe you have the same problem I have with my quadra. They have a fuse that is located in a very hard to reach area in the lower section of the unit. You have to look very closely to even find it. It's sodered in place place so one can't just change the fuse and turn it back on. Mine is blown and I can't figure out how to remove it. I was wondering if I could just by pass it but that wouldn't be safe.
Top Honeywell Air Purifiers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
