Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Where can i find the repair manual for frigidaire freezer model lffu1465dw6
Posted by GENE on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Gene, thank you for your question! I understand you are seeking a repair manual on your Frigidaire freezer, LFFU1465DW6. I have located the Owner's Guide, Wiring Diagram and Parts Manual on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Posted on Aug 19, 2013
1 Related Answer
Anonymous
  • 1218 Answers
SOURCE: I own a Frigidaire Upright Freezer/not freezing...
Good day,
If the unit is running but not cooling then check the following.
1. The fan motor behind the rear panel is not running, you will have to remove the panel, being careful not to damage the control thermostat, and inspect the motor, and replace if needed.
2. The defrost system has failed, icing the coil behind that same panel, and not circulating air. There are 3 parts to the defrost system, the main heater, a calrod unit mounted on the bottom of the cooling coil, a defrost control thermostat which is located on that same coil, but on the top. It is a small 1" round disk with 2 wires coming out of it.
Lastly, a timer which is located on the back of the machine and determines how often the unit defrosts.
If you have an ohm meter and know how to use it, you can test the heater and control thermostat for continuety if the coil is indeed iced up. If not iced up, the test will not work.
To test the timer, you take a screwdriver and with the machine on, turn the shaft clockwise until it shuts off. wait 35 minutes. If it turns the machine back on, it's O.K. If not, it needs replaced.
A tutorial on defrost systems is at the end of this post.
3. If none of the above work, then it is in the compressor/sealed system. This machine has had many issues in this area and is a serious problem unless...........
The unit is under 5 years of age, then warranty will cover the repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Posted on Jan 14, 2010
What size (cubic feet) is the Frigidaire Freezer Model # FFU17FC4CW0
I am going to guess that it is going to be around 17 cubic feet since that number is in the model number, at least that is how current models are labeled. Here is a link to a copy of the owners manual if you need it.
FFU17FC4CW0 FRIGIDAIRE FREEZER Manual
Here is another link to a page where I looked up the age of your unit and it will give you an idea where to look that up as well.
Appliance411 Service How old is my appliance Age finder date of... Hope this helps!
Feb 18, 2015 | Frigidaire Freezers
Do you have a manual for a Frigidaire Freezer upright with model number FFU1464FW1
Hello Lasondra, that's a great question!
I have successfully located the Owner's Guide of your Frigidaire freezer, FFU1464FW1. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Frigidaire Manual Search Results
Sep 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What size is a frigidaire freezer mfu17f3gw6 ?
Good Afternoon Claus, that's a great question!
Your Frigidaire freezer (MFU17F3GW6) has a total capacity of 17.0 cubic foot. I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Jul 12, 2014 | Frigidaire Freezer Refrigeration White...
How do i install a new door gasket/seal on my Frigidaire upright freezer model # LFFH21F7HWA ?
Good Morning Friend,
I understand you want to know how to install a new door gasket on your Frigidaire freezer, model# LFFH21F7HWA. Typically this is not a do it yourself repair, as there are no step by step instruction manuals that will tell you how to do this. I suggest either contacting the manufacturer or your local authorized technician for further assistance. The technician has been trained on your specific appliance, and should be able to replace the new gasket with ease. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire 20.3 cu. ft. Upright Freezer...
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
Freezer defrosted by itself and fridge is not as cold as usual
Try adjusting the Thermostat switch first (increase coolness). Stillyou have the same problem, take it for repairs.
Oct 06, 2010 | Frigidaire Freezer Refrigeration White...
Good day,
Jan 14, 2010 | Frigidaire Freezers
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
377 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
