Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Fax machine error code 021
Panasonic panafax UF 885/895
Machine does nothing but does dispaly the error message above
    Problem Solver:
  • 5 Answers
If a new toner cartridge doesn't take care of it, replace the fuser.
Posted on Apr 09, 2009
Our fax has the following error message: Printer
Press
Function
7
monitor key slowly 4 times
6
scroll sdown to SHIPMENT SET
set
wait for the machine to initialize
Nov 24, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 021
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax uf-895 faxes, won't print. Put a new toner in, gives message 021
Error 021 relates to the Fuser unit (the bit that gets hot inside).
It is not related to the toner, which is a bit strange, but try switch off/on first.
Failing that you may need to clear the error in service mode. To access this:
Press "Function", "7", "Monitor" four times, then "*".
The machine should be saying "Service Mode"
Then press "7"
The machine should say "LBP Parameter Set"
(not 100% about the next bit but it should be reasonably straightforward to follow the display on the machine)
You are looking for "LBP Fuser Reset"..I think it is this:
Press "2" for "LBP Fuser Reset"
Press "Start"
The machine may reboot at this point.
If this is done correctly and the error still remains, the Fuser Unit will need replacing.
Sorry to be a bit vague on the instructions..not worked on these for a few years :)
Jun 19, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
ERROR CODE #021
Try a new toner cartridge. If that doesn't take care of the problem, it's the fuser.
Apr 08, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Printer error message
Thank you for getting back to me. I posted the question in a panic before I dug around fixya.com and found a solution myself.
Link — http://www.fixya.com/support/t331402-code_error_021.
I gave it the best rating and can't believe how the site saved my evening.
All the best.
May 25, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
UF 585 Fax Machine Message in memory
if its only a few % like 1, 2, or some thing its probably nothin retrievable, you can have a tech come and clear it but if all else is working and the mssage in mem file dosent keep growing try and ignore it till next service
May 05, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic uf885 error
Same here. I replaced the fuing unit but he error code 021 still is present.
Apr 01, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF880 shows message to check printer
This is a fuser problem (the hot rollers)it will require a service tech the machine has overheated and there is a service lockout to stop more damage from happening
Jul 25, 2007 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
594 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
