SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
SOURCE: CPES389AC3 - Frigidaire Gallery Oven - Element and broiler
The element has blown in the oven you will need to fit a new one,and possibly the broiler one as well.
Plz rate this solution.Thanks.
Posted on Dec 24, 2008
SOURCE: I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Posted on Mar 21, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
Jun 03, 2015 | Frigidaire Ovens
Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Aug 09, 2012 | Frigidaire Ovens
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
May 29, 2009 | Frigidaire 30 in. Electric Gallery Series...
May 21, 2009 | Frigidaire 30 in. Electric Gallery Series...
Dec 20, 2008 | Frigidaire FEB30S5DC Electric Single Oven
Jan 26, 2021 | Ovens
24 people viewed this question
