Computers & Internet Logo
Configuring Laptop for Flat TV S-Video Connection.
I have connected an Advent 7096 -331S Laptop to a Flatscreen Digital TV usyng S-Video.The Sound is no problem, but how do I configure the ATI Radeon XPress 2000M 1GP Onboard Video Card for an Second Monitor (Clone)? Is there a TV Setup Wizard ?
Your help would be greatly appreciated.
A.Hill
Posted by ashvhill on
  • Anonymous May 11, 2010
    What operating system are you running? XP or Vista?
Zulfir Sadat
  • 73 Answers
Greetings,
Connect the second monitor to the blue VGA port. Download catalyst control center from the below link and install it. Using catalyst control center, you can configure dual monitor. You may need to check 'force tv detection' setting in catalyst control center.
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/9-3_xp32_dd_ccc_wdm_enu.exe
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Posted on Apr 11, 2009
I have connected my dell dimension e521 to my polaroid flm-1911 flatscreen via vga. i'm not getting any sound though.
VGA connections will not support sound, you need a separate audio cable from the pc to tv. If HDMI connection available on the computer and tv, a HDMI cable will carry both sound and video.
Excellent picture but no sound
This problem has 3 possibilities, that your tv audio output is already damage or the cables that connecting to your tv and digital reciever is loosed or damage and may be your digital reciever sound pre amplifier is damage. Let's start to your tv, try to use a dvd player or cd player and connect it directly to your tv audio video input, or you can remove the connection from the digital receiver and use a small piece of wire then connect it to your tv antenna input and set your tv mode to aerial tv.If the tv produces sounds your tv is ok. To wire connection, first try to check all the cables that connecting to your tv and digital receiver specially the input, output connection,If wire is ok. Then the digital receiver has the problem try to contact service provider and ask if your digital receiver has a warranty.
Can you explain how can i view my advent 5421 laptop on my flatscreen tv - thanks - patrick
Hi Patrick,
If your tv has a VGA connector:
greed03.jpg and your desktop should have one too, you can use a VGA cable with males ends to connect to your TV.
Once it's connected, you might have to change the video mode on the TV to see your computer screen.
Hope this helps!
Gary
I have a ps3 and a samsung flatscreen im using an hdmi cable is there anyway to run the sound through my kenwood vr 305 since it doesnt have a hdmi input
Connect cables from your flatscreen TV (or monitor?) to the receiver's audio input jacks. These could be two RCA, white and red, or Digital (one single RCA cable), or optical, if both the flatscreen and the receiver have such connector. Make sure you select the correct audio input on the receiver to amplfy the sound from the game/movie/etc.
If successful, try muting the TV's audio, to prevent the sound from creating a hollow (echo) effect.
Having a problem connecting HP G50 laptop to TV
You will have to select the input for this connection.
1helpful
Want to connect laptop to tv
The specifications on your computer suggest that it has an S-Video port, which can be used to connect it to a TV; provided the tv has an S-Video input port on it.
Additionally, this will put a picture on your TV, but sound will have to come from somewhere as well. Most laptops have sound and speakers built in, but if you are watching TV, you will never be happy with that sound.
I have run a speaker connection from the outputs on the laptop to the outputs on the TV with success. When I did this, I used the video/sound cable that came with my video camera. It had a stereo male plug at one end that fit into the laptop and the other had two RCA plugs, one yellow and one red.
Typically, the yellow is for video, and red and white are for sound. In this case, I used the yellow for sound and it worked out fine.
All this information is based on the premise that your TV will support this connection. If not, you may be able to connect to a VCR (remember those things?) and run it that way.
good luck.
tony
1helpful
Cant connect wireless internet connection
pls configure first WAN setting WI FI AREA NETWORK,IP address connection from the router wi fi,subnet, and protocol.
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
hi if you laptop has the s-video you can connect that to the tv an it would work
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Marvin
Marvin
