SOURCE: Is there a WPS button,
http://www-security-camera.com/d-link-dcs-930l-mydlink-enabled-wireless-n-network-camera/
This is a "plug and play "device ...and all you have to do is to open it and let it find the network ..and after that will be visible in your network places folder...and a device ..
if you want a more advanced control you should install the software that came with it ...
It may be necessary to change the security and remove the password while connecting ...or ..if you have a mac access set to the router ..add the camera's mac to it ...
It is supposed to find the network and connect to it auto ..once you enable the wireless connection on it ..
Also if you preset the IP range in the router ..you may need to enlarge it so that the camera 's IP to be in that range ..but Im not that sure about that ..cause it is a wireless device and it may have no issue of that kind..Just take a good look at it ..cause it probably has a button you need to enable for instant auto access ...
SOURCE: Does the d-link airplus xtreme g model DI-624
According to dlinks page here http://support.dlink.com/emulators/di624_revc/help_home.html
This router doesn't have Wi-Fi Protected Setup (WPS) as an option.
SOURCE: i am trying to hook up a netgear universaL WIFI
The dlink dir 615 wireless router hasnt got wps. So its no good trying to connect it via that way you can only do it via wep or wapor wap2 here is a link to the manual for your router http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
SOURCE: I'm trying to connect a
There is no WPS button on the WBR2310 router. Simply connect to it like you would any other device, such as a computer.
