Toys Logo
Question about Toys
Lionel 671m-1 motor tries to turn but just rattles
The wheels on Lionel The Polar Express LionChief 2-8-4 don't move, or are stuck.
Please make sure that the wireless controlloer power switch is set to "on." Please also give the train a new command. If it does not start to run, either your engine or remote need repair and you would need to reach out to Lionel by calling 1 (586) 949-4100.
Thank you.
Lionel troubleshooting
Two steps: (1) verify all wires are connected (use a Volt Ohm meter if you have one.
(2) If there's a motor involved (and I assume there is) ... first try cleaning the brush end (that touches the commutator) with alcohol, and lightly sand with 400 grit sandpaper (keeping it as flat as possible). If that doesn't work, try stretching the brush springs slightly. If that doesn't work, try replacing the brushes with new ones ... (and they generally come with new springs).
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
New polar express motor wont engage
It sounds like the gears have worn out or come adrift somehow. You will be able to get replacement gears from any of the Lionel authorised dealers Lionel Authorized Dealers or their replacement parts service Replacement Parts
Where can I find a replacement motor for Lionel 6-24137 Mr. Spiff and Puddles accessory
Here is a link to contact Lionel Parts & Services:http://www.lionel.com/ContactUs/
They'll be able to supply you with a motor.
2answers
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
Dec 22, 2012 • Toys
Parts to fix train with failed component
You've done the right thing by talking with Lionel. Their techs should be able to guide you trough trouble shooting as it seems that you have some knowledge of electronics.
1helpful
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
4helpful
Anniversary train clock; clock does not work
It's not the motor it's the unit in the middel that works the clock it self. I have the same problem. When the clock passes the hour it is supose to send a signal to start the motor. There are two tiny pices metal that are supose to contact each other on the hour and they break off easy.
You have to replace the clock unit and reconect the two black wires.
Try by passing it. The two black wires that come from the clock unit. Cut them and touch them together. Make sure the light sencer on the front is not covered.
Good Luck
Jan 16, 2009 • Toys
Open Questions:
Top Toys Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Toy Expert? Answer questions, earn points and help others
