Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
MT-1000 Charger flashes red and green when battery in charging
3 Related Answers
eradiostore
eradiostore
  • 1667 Answers
SOURCE: Red light flashing
It is either defective, or it has something touching one of the contacts causing a short. It would be best to replace the charger. Typically they are somewhat like a light bulb, they will burn out over time and need replaced.
Posted on Jan 18, 2009
eradiostore
eradiostore
  • 1667 Answers
SOURCE: ntn7143cr battery won,t charge
Clean your battery contacts on the battery and charger with a pencil eraser to assure good contact. Flashing red or flashing in general usually is the sign of a too low to charge battery, a shorted battery or a bad connection. In some instances, a battery will begin to charge once left on the flashing charger for an hour or so. Try this and see if the light becomes constant. If so, it is charging. If it still flashes, replace the battery.
Best regards.
Posted on Apr 07, 2010
eradiostore
eradiostore
  • 1667 Answers
SOURCE: When I try to charge
1) Hand oil can cause a film on your battery contacts. Clean your battery contacts on both the radio and the charger with a pencil eraser and try seating the radio/battery on the charger again. Be certain the radio is turned off.
2) It is possible your battery is too low to charge. A form of jump starting would be to let the battery set on the charger for more than 3 hours to see if the light problem clears.
3) It is possible you have a bad or shorted battery. Try another known good battery on the charger to see if the charger reacts correctly with a solid red light at the beginning of a normal charge cycle.
Best regards.
Posted on May 27, 2011
My charger flashes red/green and does not charge my scooter. Any suggestions?
hi the red led should not flash the green led should only come on when batteries r charged while charging the green led turns orange or yellow....can u borrow another charger just to check to c if its not the scooters charging circuit that is the problem..or the batteries ..good luck
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
1helpful
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
5helpful
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
3helpful
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
3helpful
2answers
The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
7helpful
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
5helpful
2answers
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Top Motorola Radio Communications Experts
Steve
Muzahura Frank
woodzowl307
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
