You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
You may try default phone and security code to remove restrictions. Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
FORGOT SECURITY CODE:please type *#06# on ur mobile..you will be able to get back ur security code...
00000.
If the default security code does not work you can use a master code to completely reset the device. That code is *2767*2878#. PLEASE use at your own risk as most times this code will erase all your phones information but also removes the security code.
Regarding PIN, there is no default PIN set up by Samsung. If you wish, you can select a PIN for your handset. The procedure is :-
PIN (Personal Identification Number) code' is a security tool designed
to stop unauthorised usage of a SIM card. You can set the PIN code on
'Security Settings'. You will then be required to enter the PIN code
every time the handset is turned on.
