Question about Dell 926 All-In-One InkJet Printer
Ink from wal-mart
Purchased black ink from wal-mart for dell's photo printer 926, then had an allignment issue. Now printer window says change left cartledge. Is there a problem with wal-mart's ink? Purchased the dell ink
Posted by Deanne Biddison on
  • pshev Apr 14, 2009
    I have the same problem but with a colour cartridge bought direct from Dell. It says "install the colour print cartridge on the right side". Tried putting the old one back in and this error code goes away but says colour ink low.
    President:
  • 2,992 Answers
Like any other product, there will sometimes be defective cartridges. Take the one back your printer is complaining about back to Wal-Mart and exchange it as defective. They'll just send it back to the manufacturer. (Sometimes it's easy to overlook the possibility a new part is bad. It's a real pain when that happens, but it does.)
Posted on Apr 07, 2009
Dell v305 printer allignment problem
Hello Michelle,
You are using Dell Series 9 ink cartridges, correct?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 9 black cartridge and then reseat it. I would then take out the color Dell Series 9 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
It's possible to get a Dell Series 9 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement.
Bhautesh,
Jan 30, 2014 | Dell Computers & Internet
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
Oct 13, 2011 | Dell 926 All-In-One InkJet Printer
It keeps printing alignment over and over
Sounds like a bad sensor in the Dell Series 9 ink cartridge.
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Jun 11, 2011 | Dell 926 All-In-One InkJet Printer
I have a Dell Photo926 printer. I just changed the color ink cartridge and it is giving me an alignment error stating remove tape from cartridge. There is not any tape on the cartridge. I have ran the...
Are you using Dell Series 9 ink cartridges?
Rick
Apr 26, 2011 | Dell 926 All-In-One InkJet Printer
DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
Follow the below instructions
  1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
  2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
  3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
  4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
  5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
  6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
  7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
I hope this clears up your problem.
Good Luck and Have a Nice Day!!
Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
Cartridge alignment problem - it says to remove tape from cartridge or troubleshooting. There is no tape on the cartidges.... HELP!
Rick
Jan 09, 2011 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer will not print with the black ink and tells me that the cartridge is incompatible even though there is ink in the cartridge and i got it from dell
Do you have a '926' or a '962' printer? You've cited each number in your problem description.
Remove the ink cartridge.
Reinsert the ink cartridge.
If the problem persists, contact Dell, and get them to replace it.
Nov 20, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell Photo 926 ink cartridges holsters won't show up
Contact the dell chat suport line on the dell.com website they are good at fixing probles even if they have to seend someone out or have you seend it in.
May 03, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 Printer ink refill instructions
Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
250 people viewed this question
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
