1990 Eagle Talon Logo
Posted on Apr 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a Eagle Talon TSI AWD 1990 175000km bought new. the motor runs flooded & the turbo is always on but sometimes it falls back to running normal, like new, the gas pump pressure was checked, the exaust was disconnected to check if the catalitic converter was plugged, the gas filter, most of the sensors, the coil & wires were replaced, air filter too & the filter unit was checked and is ok. Thank you in advance for the advise, it is a Canadian one, Andre
Anonymous
Level 2:
Scholar:
  • Expert 147 Answers
  • Posted on May 10, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
147
Questions
0
Helped
85562
Points
481
They fail sometimes you need to make sure the snail has good bearings ..plus after its been boosting if its been turned off right away thats not good..with higher milage i would do drivability checks before i tear up a wastegate or charger ..your timing should be retarded a bit to boost correctly.
2answers
Turbo 93 eagle talon
i have fitted a new thermostat heat working fine. but temperature gauge not working
2answers
93 talon tsi getting fuel and spark car cranks but wont start
I would try making sure spark plug wires are put on in the correct firing order. This is a common mistake in tune ups. Most intake manifolds have the firinging order cast in. Plug gaps correct? I cant come too far away.
Will a 91 fwd turbo talon flywhell work with a 95 tsi awd talon trans
no the configuration is much different to the bolt pattern and they are also balance differently as well. You can not mis match these or improvise there fit what so ever or internal engine damage will occur
2answers
I own a pristine '91 eagle talon tsi awd 5
check buscher racing.com or call them they know it all when it comes to talons and dsm's
Boost cut
Too lean on boost. Not enough fuel.
1helpful
Recently bought a 92 eagle talon tsi awd turbo ''automatic'' and the turbo guage dosen't work the person that i bought the car from said that he replaced the turbo seal that was leaking oil into the...
First things first. Do not bother trying to use the stock boost gauge in that car, it runs off of the ECU and it estimates with small calculations what the PSI may be, the stock boost gauge is ushally 2-3 psi off.
What i recommend is getting yourself an aftermarket boost gauge you can get em used locally on craigslist or a cheapy one from a reputabile ebay power seller. or pick one up for 40-60$ from autozone.
After you do that mount it in a good location, they are very very simply to install, if yours does not come with an instruction paper, you can search boost guage install on dsmtuners.com or yahoo or google.
BUT BY ALL MEANS DO NOT TRY TO FIX THE STOCK GUAGE, YOU WILL NEVER KNOW THE ACTUAL PSI READING.
1helpful
95 Eagle Talon TSI AWD Turbo (rocker panels)
Try eBay. DSMhp.com, DSMTuners.com, etc. Most of the forums have buy/sell sections that will fit your needs. You can google DSM forums (DSM is Diamond Star Motors, which relates to where the Talon/Eclips/Laser were produced in Ohio) and find many that can help you and perhaps one close to your location.
Top Eagle Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve Sweetleaf
Steve Sweetleaf
Are you an Eagle Expert? Answer questions, earn points and help others
