SOURCE: fills the hums loudly
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
SOURCE: Kenmore Mod 70. Spin and drains fine, no agitate.
The movie
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
