Question about Epiphone Les Paul Studio Electric Guitar
Output jack on a Epiphone Les Paul came out and I ned a schematic
I need to know how to solder this back properly..any help?
Posted by evan_lowe on
Anonymous
Google your problem. i have found scematics on everything. i'm currenly changing out the pickups on my les paul, and saw the diagram on your soldering setup. i've done these myself. i was a little worried at first, but it turned out to be pretty easy. good luck, scott
Posted on Apr 08, 2009
  • Painter33 Feb 16, 2015
    The output jack has two soldering lugs. The center lug (on top) is the ground that wires to a pot, and the inner ring lug is the hot lug that goes to the switch.
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
In middle of concert epiphone stopped, took it apart where plug goes in wire came off , but can't figure out where to solder it back, it is one wire with outside ground?
If it is a coax with a wire in the center and a shield outside, the wire will attach to the contact that touches the tip of your plug you insert. The shield will attaach to the part that touches the sleeve of you plug. inspect the jack carefully as they can be foolers. When stripping the insulation back un-braid the shield a little to be able to solder it to the jack. Use a pair of needlenose and a helper to keep soldering heat from going up the braid and melting the insulation of the internal wire. Test unit before putting cover on.
Apr 25, 2011 | Epiphone Les Paul 100 Electric Guitar
Wiring
Here are links to a standard LP wiring diagram and a LP Jr. wiring diagram. Absolutley free at stewmac.com
http://www.stewmac.com/freeinfo/Electronics/Wiring_diagrams/i-1217.html
Jun 17, 2010 | Epiphone Les Paul Studio Electric Guitar
Fix the wiring in a epi lp100
http://www.1728.com/guitar.htm
Its basic diagram #2.....but a twin pickup les paul is a twin pickup les paul!
May 06, 2010 | Epiphone Les Paul 100 Electric Guitar
How do i choice to buy a custom epiphone les paul
If you are on a limited budget then get a standard Epiphone Les Paul. The Custom is not much better. If you have a little more to spend then I recommend getting a new or used Gibson Les Paul Studio.
Narrowing down which guitar to buy is completely opinion-based. You need to try multiple guitars to find one you like best since they all feel a little different.
Oct 01, 2009 | Epiphone Les Paul 100 Electric Guitar
Need to replace output jack and plate
If this is a classic guitar you should take the fretboard problem to a luthier as you could de-value the unit by working on it yourself.
The jack you can replace yourself. Just connect the wires to the new one the way they came off the old one. There are ONLY two wires. You can get replacement jack from severaal sources.
Aug 24, 2009 | Epiphone Les Paul Studio Electric Guitar
HELP!
This is exactly how any 2 pickup, 2 volume, 2 tone, three way switch guitar would be wired from the factory. Best of luck!
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Apr 01, 2009 | Epiphone Les Paul 100 Electric Guitar
Low volume on front pickup of Epiphone Les Paul
i have an old sg, and this happened to me too. the repair guy told me that inside the p/u, the windings were broken, resulting in a lower output. go on e-bay, and look up a neck pos. humbucker. there everywhere. or do yourself a favor, and do what i did. i have an epi. flying v, and epi. les paul. on e-bay, i bought gibson 57 classics. i put these in both my guitars, and i now have great sounding guitars. you will not belive the difference. good luck, scott
Jan 31, 2009 | Epiphone Les Paul Studio Electric Guitar
Getting Static noise when plugged in to amp
This is a very common problem that I have repaired for many friends. Sometimes the guitar jack becomes loose and gets rotated to the point where the wire breaks and/or touches the cord plug when it's inserted into the jack. You need to remove the access plate/panel at the back of the guitar body and see if the wire is broke or twisted. You may only have to loosen the jack retaining nut and rotate the jack to get the twist out or you may have to remove the jack and resolder the wire back in place. If its broke make sure to solder back on the proper terminal--the one with solder already on it and not the one that the cord plug touches when its inserted. Retighten the jack nut by firmly holding the jack from access side so it doesn't rotate again and cause that undesirable STATIC sound. Hope this helps.
Dec 08, 2008 | Epiphone Les Paul Studio Electric Guitar
Epiphone Les Paul Studio Electric Guitar Logo
803 people viewed this question
Top Epiphone Music Experts
Robert Graf
Harrie
Marvin
Marvin
Are you an Epiphone Music Expert? Answer questions, earn points and help others
