Question about Sony SLV-D360P DVD Player/VCR
Sony SLV-D360P player DVD won't eject, says "Lock"
The DVD/VCR player was moved with a DVD in it. Now when I try to use it, it plays fine. However, when I try to eject the DVD, it says "Lock" and won't let me eject it.
Posted by kaiserchick on
  • Anonymous Apr 07, 2009
    Sony SLV-D360P player DVD won't eject, says "Lock"--how do I fix this?
Anonymous
Hold down the
Posted on Aug 27, 2009
  • scott_r_armo Sep 03, 2011
    Hold down the what???
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My dvd locked in the sony slvd 360p dvd player. how do i eject the dvd from the dvd player?
Open the door to the DVD.. You will see a white plastic wheel inside with "teeth"- like a gear. Use something small to turn the wheel to the right. When it feels like it won't go any further give it a little extra turn and the drawer should pop open. Make sure you are turning it to the right (clockwise)
Oct 29, 2010 | Sony SLV-D360P DVD Player/VCR
Sony blue ray player won't eject DVD
I have a new Samsung Blue Ray player. I cannot figure out how to eject the DVD. Can anyone hepl me. I do not see an eject button on it anywhere.
Apr 10, 2010 | Sony SLV-D360P DVD Player/VCR
I need the manual for sony slv-d360p dvd player
You can download the operations manual in PDF format from this link.
SLV-D360P
Hope this helps you.
Sep 24, 2009 | Sony SLV-D360P DVD Player/VCR
Vcr/dvd combo, vcr no longer will play tape, when I press play, after a few seconds will eject tape.
Hi
Thanks for using FixYa. Please check the eject mechanism and the drive motor connected with the tape mechanism. Try and align the drive motor. Also check the push-pull arm of the tape mechanism and make sure that the springs connected with the mechanism are fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Sony SLV-D360P DVD Player/VCR Logo
1,266 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
