SOURCE: Dell Inspiron laptop will turn on but wont take me to log in screen
Shut down the computer and then hold Fn key and then press the power buttong which will take you to Pre Boot Assesment test so let the test run and if hard drive is failing it will give you an error.If you want to do extended test then once this PSA test is finished it will ask you wether you want to remaining memory test just say yes and after that run the extended test which test the computer components extensivly and by that you can make sure wether hard drive is fine or not.If everything passes then reisntall Operating system or if you want to try to repair then boot from vista dvd (if vista) and then choose option repair.Let me know if further help needed
SOURCE: process smartmenu.exe has a volume bar that
first of all u have to remove it from ur startup menu then search any service which support this process and remove it from ur startup Services.
procedure:
window+R
type msconfig and press OK
do above procedure
SOURCE: Acer Aspire One D250-1042 shows desktop wallpaper but won't load
Start by logging on as the Administrator so you can check the Task Manager and find out what Application or Process is monopolizing the system.
If the system is still unresponsive boot into Safe Mode. (Press F8 before the Windows startup screen appears.) If everything is fine in Safe Mode type MSCONFIG at the Command Prompt and start disabling features until you find the culprit.
Last resort, buy or borrow an external USB CD/DVD drive and use it to reinstall Windows.
Important: Reinstalling will ERASE the hard drive.
If this helps please vote for my solution.
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don't forget to vote
